RH 11 Webhelp
Our master page footer text looks good in a shaded border, but there seems to be no way to set the distance of the border from the Help content. I was able to set the distance by 1) removing the shade & border and 2) selecting the text and setting the paragraph Spacing Above to 18 px. It looks fine, if plain.
Is there a way to:
Also, is 18 px deemed a good Space below content, or has someone seen a different recommendation?
Thank you
If you use the CSS selector #footer, you can do anything you want:
#footer {
margin-top: 18px;
to set 18px as a top margin.
Personally, I would set it to 1.5em (16px x 1.5) for a distance. It's more than a line height, but enough to indicate it is part of the content.
Kind regards.
You might use a transparent image to control it.
Cheers... Rick
#footer {
margin-top: 18px;
Kind regards.
Hi Willam,
Thanks! I set it to 18 px using RoboHelp's paragraph settings. It looks good, and was what I needed to know about the amount of space that was appropriate.
Cheers
Hi Rick,
Thanks very much! While there was an easier way for this need, I'll keep transparent image in mind - sounds like the sort of tip that may come in very handy sometime, and not something I would have thought of.
Cheers
