When running this it is only giving me the last value of my query in the array. Any thoughts on why this is happening? I appreciate any assistance. Thank you
<cfset result = arrayNew(1) />
<cfset ArrayMedSchools = structNew() />
<cfloop query="GetMedSchool" >
<cfoutput>
<cfset ArrayMedSchools.name = Institution />
<cfset ArrayMedSchools.id = InstitutionID />
<cfset arrayAppend(result,ArrayMedSChools) />
</cfoutput>
</cfloop>
<cfset ArrayMedSchools = structNew()/>
<cfdump var="#GetMedSchool#" label="Original Query">
<cfdump var="#result#" label="resulting array">
I figured it out.
I had the <cfset ArrayMedSchools = structNew()/> outside the loop instead of inside the loop.
So your query has X rows. Does your array have the values for the last row in your query, duplicated X times? Or does it just have one element, with the values from the last row in the query?
One thing you might want to try is resetting the structure within your query loop:
<cfset result = arrayNew(1)>
<cfset ArrayMedSchools = structNew()>
<cfloop query="GetMedSchool">
<cfset ArrayMedSchools.name = GetMedSchool.Institution>
<cfset ArrayMedSchools.id = GetMedSchool.InstitutionID>
<cfset arrayAppend(result, ArrayMedSchools)>
</cfloop>
Also note that you don't need to use <cfoutput> within your loop there.
Here you go... this is how you would want to do it.
<cfset result = [] />
<cfset result[ArrayLen(result)+1] = {name = GetMedSchool.Institution, id = GetMedSchool.InstitutionID}>
</cfloop>
HTH,
--Dave
I figured it out.
Thanks everyone for the responses. This was nagging me for the past 2 days.
While your "solution" may have fixed your issue the code is still sub optimal. You don't need to create a var for the struct and you have improper user of cfoutput.
--Dave
