Personal URL on myspace
Jul 10, 2007 Jul 10, 2007
Hi everyone,
I'm trying to duplicate the same effect on my site that myspace.com has on theirs. What they do is give each person a unique url that they can use in promotion. However, when a user clicks, they are sent to a page that is taken from the database.
Here is what I mean:
This is the url that I use to go directly to a person's page: http://www.myspace.com/myuniquename
This is the real url that is brought up: http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=123456789
Can I do this without creating a lot of folders on my site and redirecting?
Simone
Advanced techniques
1.0K
Advocate ,
If you are using unix / linux servers then you may use the "ln" command and through that you can create "Symbolic links" which look like directories which are actually act as links to one common directory..
Engaged ,
The easiest to implement would be to parse the cgi.path_info. Though not exactly like the MySpace site, the url would include an index.cfm as part of the pathing.
http://www.myClone.com/index.cfm/myUniqueName
Look at the ParseURLData UDF at http://www.cflib.org/udf.cfm?ID=378
A little more complicated is to use something like Mod_rewrite ( http://www.google.com/search?hl=en&q=IIS+mod+rewrite ) which would be handled at the web server.
Jul 19, 2007 Jul 19, 2007
I'm looking for the same thing. Any way to do it through Cold Fusion and not IIS?
What about:
http://www.myspace.com/application1/myuniquename/
http://www.myspace.com/application2/myuniquename/
http://www.myspace.com/application3/myuniquename/
Could you have CF read the url first?
<cfif SCRIPT_NAME listcontainsNoCase(application1)>
Len( http://www.myspace.com/application3/) - Right (myuniquename/)
<cfset member="myuniquename">
The code above is choppy and would need some cleanup But you get the idea...
Would it work?
Could
I used this method: http://www.myClone.com/index.cfm/myUniqueName
on the index page, I parsed the URL using cgi.path_info and redirected to index.cfm?fuseaction=circuit&id=uniqueid
I haven't figured out how do to it with http://www.myClone.com/myUniqueName.
Anyone else have any ideas?
Engaged ,
Yes ISAPI rewrite on IIS or Mod_Rewrite on Apache. They are both designed to do exactly this rather than a hack, bear in mind the cgi.path_info wont work on some web server set ups.
I'm on a host and don't have access to the web server.
-- Simone
Engaged ,
Jul 20, 2007 Jul 20, 2007
Then only the http://www.myClone.com/index.cfm/myUniqueName will work. I would find a host that has Apache and lets you set RewriteRules. It is incredibly powerful and can do much more than just the aforementioned pattern matching!
Sorry - I replied to the wrong forum.
Jul 25, 2007 Jul 25, 2007
Actually a technique we use is a 404 redirect. Meaning upon any given url not being found for a site ie. www.blah.com/fake directory/. IIS takes that 404 error and sends it to CF, on that CF page you take the cgiQuerystring.. do some logic and then either display your info or do a cflocation redirect.
Aug 03, 2007 Aug 03, 2007
This sounds like a good method. How do you check for the bad directory name?
-- Simone
Documentation
