0 Replies Latest reply: Jul 28, 2014 7:17 AM by Bill Vojtech RSS
    Is there a way to select every other page in a multi page pdf and convert it to grayscale?
    Bill Vojtech Community Member
      I'm going to ask this question in a few sub-forums, so if you think you've seen it, you might have.
      Where I work I use a program that can print to pdf. We use it to produce mailings, usually postcards, that are addressed.
      I often end up with a 500 page document that will print on 250 sheets of cover stock, which will get cut into 1,000 postcard, all pre-addressed and sorted by zip code.
      Usually, the address side is all black and the front is color. The printers we use can print a black click on the address side and a color click on the other, IF the pdf is set up that way. Otherwise, both sides will be counted as color clicks.
      I know I can select pages individually in a pdf and convert them to grayscale and those pages will be counted by the printer as black clicks, which are cheaper than color clicks.
      The problem is, I have not figured out how to convert all the odd numbered pages to grayscale at once. As a result, I usually end up printing the color side simplex, then putting the job back in the tray and printing the black side. Of course, that only works if only one side is personalized, sometimes both sides are.
      Is there a way to select every other page in a pdf and convert it to grayscale?
