Why the new Adobe Muse CC (2014) is asking me to put a serial number?? I have a Creative Cloud membership for Muse product that i pay per month.
Creative Cloud applications unexpectedly revert to trial mode | CS6, CCM
Creative Cloud applications ask for serial number
Creative Cloud products launch in trial mode on non-English operating systems | CCM, CS6
Try all the thing above, but nothing works. Help please!
Thanks.
You will need to remove any line in your hosts file that contains Adobe servers. This can block your machine from activating Muse.
Mac: /etc/hosts
Win: C:/Windows/System32/drivers/etc/hosts
You'll need to restart Muse after editing and saving the file.
Please let me know if this works.
Chat Now button near the bottom for Activation and Deactivation problems may help
http://helpx.adobe.com/x-productkb/policy-pricing/activation-deactivation-products.html
Hmm.. Not working. It's funny because if i close the popup window with the options "license from this software" or "Continue the trial version" , Muse works correctly... It is a bug or the 30 days trial period are counting?
serial number
adobe application manager is causing conflict, if you tried to install illegally look for any folder or application Adobe aplication manager and I removed and emptied the trash, in my case use Clean my Mac, but empty it works, then muse and I try to open Adobe Aplication Manager thought this was necessary, I went to applications / muse / uninstall, delete the same way everything related to creative cloud even from applications / utilities and emptied the trash and went to download the desktop application on my mac, installed it, got an error but will try again, installed, download Muse and ready! worked (for me, maybe also helped remove the records in the hosts)
me too. All of my apps including Acrobat(!) are doing the same thing for the past week.
Can we get a pro-rated refund for the time we can't access our software?
same problem
this is apparently an issue. i had tech support do remote access for an hour and they fixed nothing. getting a a little ridiculous.
Hi Everyone,
If you cannot reach https://lm.licenses.adobe.com/aents/status.jsp please ensure that it is not being redirected in your hosts file (C:/Windows/System32/drivers/etc/hosts on Windows, /etc/hosts on Mac) and that no firewall software is blocking attempts to reach the lm.licenses.adobe.com server.
Colby
for me this happened on two different machines, on two separate networks at the same time. I'm quite convinced this is Adobe's issue for most of us.
If Muse worked BEFORE the update, it should work AFTER the update. I'm not sure why it would all-of-the-sudden be blocking attempts to reach the licenses server?
r3vvedup and Bfirst786 - Are you able to reach https://lm.licenses.adobe.com/aents/status.jsp in your browser?
no. I've done all the workarounds WRT my firewalls and hosts files, etc. Adobe's PR reps said "it's the user's fault for signing out" Adobe Creative Cloud 2014: Progress and pain in the usual places • The Channel
The thing is, not only didn't I not sign out--CC App manager didn't give me the option to sign out. And this happened simultaneously on two machines connected to different networks.
no. I've done all the workarounds WRT my firewalls and hosts files, etc. Adobe's PR reps reportedly recently said "it's the user's fault for signing out"
nope...doesnt work for me
Mac: /etc/hosts
Bfirst786 Please send me these files at muse-support@adobe.com with ATTN: Colby in the subject line:
Mac:
/etc/hosts
~/Library/Logs/amt3.log
~/Library/Logs/oobelib.log
~/Library/Logs/PDApp.log
Win:
C:\Users\YOUR_USER_NAME\AppData\Local\Temp\amt3.log
C:\Users\YOUR_USER_NAME\AppData\Local\Temp\oobelib.log
C:\Users\YOUR_USER_NAME\AppData\Local\Temp\PDApp.log
Colby
So true. I have the older Muse CC and I'm able to run it as well as update without any issues.
Muse CC 2014 is the problem.
One more reason I hate this subscription model.
One of our users had the same issue.
We started Muse 2014 in trial mode a few days ago.
Today he has manually activated it and now working.
Resolved
remove any line in your hosts file that contains Adobe servers (127.0.0.1 lm.licenses.adobe.com) Now Adobe Muse Works
Thanks! Colby Ausen, great work
i deleted the hosts file completely... is that bad, or does it rewrite itself? because no everything seems to work.
chemoletter I wouldn't recommend deleting the whole thing, it's possible there were other redirects in the file you might need. The only lines that need to be removed are ones with "adobe" in the URL.
Many of us had a friend install Adobe Photoshop or any other program on our computer without purchasing the software from adobe and to be able to do so the host file needed to redirect the adobe site t avoid conflicts. now installing the new Muse requires for validation and customer support recommends removing these redirects but if we do so will all other software installed stop working? I understand that there's is the right way to do things and then "workarounds" and some of us are stuck with a workaround someone else did and now are paying for this, is that right?
Host redirects for Adobe servers interfere with legitimately purchased software. The fixes I've suggested are likely to cause pirated Adobe software to stop functioning.
Hey thx, good to know I stop my CC license.
