I recently switched to RH 11 and I noticed that I cannot add pasted text when I'm hyper linking. I've tried copy and pasting from another program into the topic and then copying and pasting again into hyperlink with no luck. This is frustrating because now I have to type out long URLs that use a lot of characters. Does anyone have an idea of what is happening and how I can fix it?
Thanks in advance!
Both work for me using Ctrl+V and the mouse context menu. Can you paste the URL's into Notepad?
Kind regards,
Willam
Thank you for your reply, William. Unfortunately, the Notepad trick doesn't work either. Maybe I will need to reload RH
I can't see how reinstalling would help here. If you can't even paste into Notepad this suggests a more general Windows issue. Can you copy / paste in other applications? Is there something about the RH project's location that could have different access rights?
RoboColum -
I can paste in other applications, including the Hyperlink box of Word. I think you are on to something in regards to the location, however. I opened one of the example projects from Adobe and hyperlinking works just fine there. My project in question is in My Documents folder on my computer rather than on a network drive.
Thanks for your reply. I will keep searching for the answer.
FYI: I am on Windows 8 and I tried running the project as an Administrator. No luck.
Where’s the project located?
Try running a copy of it in a c:\projects\ folder that you’ve given full rights to.
Jeff -
First, this is my personal machine so I have access to all drives. It sits in the My Documents folder (under My Computer). I've copied it elsewhere to see if that helps and it does not.
Maybe this is important to know: I created this originally with RH 9. I skipped the 10 version and just recently upgraded to 11. Everything else about the project seems to operate normally.
You had mentioned that it was a Win8 machine someplace I recall – from Vista onwards, MS has been trying to protect ourselves by limited access to folders on our own machines even though we are admin users. You still have to right-click > Security and grant yourself Full Control to a folder. Anyway, RH always likes short path names to projects. Assuming you’ve got all RH updates loaded, have you tried deleting the CPD file? It gets recreated each time you start up the project, so it’s safe to blow it away.
Jeff, I would amend that statement just a tad.
Actually, *If RoboHelp sees the file is missing* RoboHelp will happily re-create it. But that's the only time. It doesn't routinely re-create it each time the project is opened. (unless, of course, one has taken the additional step of configuring RoboHelp to re-create it each time.)
Cheers... Rick
Unfortunately, that didn't work either. Thank you though for the suggestion.
To clarify, deleting the CPD file is what I tried. I have also checked to see that I have full control over the file and folder, and I do.
What is the length of the URL? Could it be over 255 characters? If so, could the link path be reduced by:
