Hi everybody,
I use Mozila Firefox, I can download it just fine, then I hit run, accept the security notification, and then here what I get every time :
I tried rebooting, didn't work.
Hello,
We have received a few reports of the window displaying without text, however, have been unable to reproduce it. We would appreciate it if you could generate and submit a log file to aid in troubleshooting. Can you please do the following:
Thank you in advance.
Maria
I did step 1 to 4, but when I hit enter it says (location of the file) isn't recognized as an intern or extern command, an executable software or a command file.
I too have the same problem for this last while. I am running windows 7 and internet explorer 11.
I also tried the above steps like Extremisss and encountered the same issue.
Hello,
Please make there there is a space between the file name and / and that there is no space between / and debug, as follows:
install_flashplayer14x32_mssd_aaa_aih.exe /debug
Maria
I installed it from firefox and it worked finaly. Thanks for the help anyways!
I am having same issue. Performed diagnostic steps. Here is output
Memory Initialized (Maximum)
Host Version: 3.5.4.25
"C:\Documents and Settings\XXXXXXXXXX\My Documents\install_flashplayer14x32_mssd_aaa_aih(1).exe" /debug
System: Windows NT version 5.1.2600.196608
Added url to whitelist (localhost).
Added url to whitelist (solidstatenetworks.com).
Added url to whitelist (snxd.com).
Added read only registry path to whitelist (machine\Software\Microsoft\Internet Explorer\).
Added common name to whitelist (Solid State Networks I, LLC).
Added common name to whitelist (Adobe Systems Incorporated).
Extracting skin file (/app.config.xml)
Added url to whitelist (get.adobe.com).
Added url to whitelist (get2.adobe.com).
Added url to whitelist (aihdownload.adobe.com).
Added url to whitelist (airdownload.adobe.com).
Added url to whitelist (ardownload.adobe.com).
Added url to whitelist (download.macromedia.com).
Added url to whitelist (fpdownload.macromedia.com).
Added url to whitelist (fpdownload2.macromedia.com).
Added url to whitelist (fpdownload.adobe.com).
Added url to whitelist (fpdownload2.adobe.com).
Added url to whitelist (platformdl.adobe.com).
Added url to whitelist (platformdl-stage.corp.adobe.com).
Added url to whitelist (wwwimages.adobe.com).
Added url to whitelist (wwwimages.stage.adobe.com).
Added url to whitelist (dlmping.adobe.com).
Added url to whitelist (dlmping2.adobe.com).
Added url to whitelist (dlmping3.adobe.com).
Added url to whitelist (dlmping4.adobe.com).
Added url to whitelist (get3.adobe.com).
Added url to whitelist (get3.stage.adobe.com).
Added url to whitelist (adobetag.com).
Added url to whitelist (promotion.adobe.com).
Added read only registry path to whitelist (machine\SYSTEM\CurrentControlSet\Control\Session Manager\Environment\).
Added read only registry path to whitelist (machine\SOFTWARE\Microsoft\Windows NT\CurrentVersion\).
Added read only registry path to whitelist (machine\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\).
Added read only registry path to whitelist (machine\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\).
Added read only registry path to whitelist (user\SOFTWARE\Microsoft\Windows\Shell\Associations\UrlAssociations\).
Added read only registry path to whitelist (root\http\shell\open\command\).
Added read only registry path to whitelist (root\https\shell\open\command\).
Added read only registry path to whitelist (root\.htm\).
Added read only registry path to whitelist (root\.html\).
Added read only registry path to whitelist (root\IE.HTTP\shell\open\command\).
Added read only registry path to whitelist (root\FirefoxURL\shell\open\command\).
Added read only registry path to whitelist (root\SafariURL\shell\open\command\).
Added read only registry path to whitelist (root\ChromeHTML\shell\open\command\).
Added read only registry path to whitelist (machine\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\).
Added read only registry path to whitelist (machine\SOFTWARE\Macromedia\).
Added read only registry path to whitelist (user\SOFTWARE\Macromedia\).
Added read/write registry path to whitelist (machine\SOFTWARE\Adobe\Setup\Reader\).
Added read/write registry path to whitelist (machine\SOFTWARE\Wow6432Node\Adobe\Setup\Reader\).
Added common name to whitelist (Adobe Systems, Incorporated).
189 active MIME types
WebServer thread running
WebServer Listening on 127.0.0.1:2931
Browser cache flushed (0 removed) (713 checked) (0.05 seconds)
Browser: IE 8.0.6001.18702
Extracting skin file (mainwindow.config.xml)
Response code set [/mainwindow.html:200:0]
Response code set [/images/icon-blank.gif:200:0]
Response code set [/mainwindow.css:200:0]
Accept queue size of (2)
Response code set [/images/icon-complete-error.gif:200:0]
Response code set [/images/icon-complete.gif:200:0]
Response code set [/compact.min.js:200:0]
Response code set [/images/logo-adobe.gif:200:0]
Response code set [/images/bg-header-error.gif:200:0]
Response code set [/images/bg-close-program.png:200:0]
Response code set [/images/bg-download-bar-full.png:200:0]
Response code set [/images/bg-download-bar-empty.png:200:0]
Response code set [/images/button-center.png:200:0]
Discovering default browser...
Default browser: "C:\Program Files\Mozilla Firefox\firefox.exe" -osint -url "%1"
Skin version: 2.0.2.7
Document ready triggered
Extracting skin file (locale/en-us.json)
Unable to extract skin file (locale/us.json)
Unable to extract skin file (locale/en.json)
Response code set [/images/button-right.png:200:0]
Response code set [/images/button-left.png:200:0]
Extracting skin file (workflow.json)
Extracting skin file (interop/downloader.dll)
Loading interop library (C:\Documents and Settings\XXXXX\Local Settings\Application Data\Adobe\downloader.dll) (3.5.4.25)
Downloader Version: 3.5.4.25
Solid Core v0.82 () in use (S11)
Cwd
Torrent Agent: -SC0082-
Torrent Agent: -SD354P-
Starting manager thread
Manager state changing from (Idle) to (Start)
Manager state changing from (Start) to (Process)
Thank you for providing the log file. We are reviewing the log file.
Maria
In order for you to get the installation done, use these installers:
