quote:
Originally posted by: CatBandit
I know that. I wasn't clear, and do apologize for that. I meant that the microphone or video card wasn't working with Captivate, not that they weren't working at all. This has been a problem for some time, specifically with regards to some USB Mic setups, and with "RealTek" audio cards. In those cases, a fix" (patch) has been made available.
The fact that you can record and playback in other programs has nothing to do with this little bug...
The fix I referred to above is available at this link . I hope this helps!
Hi, I know this is an old question.
You don't need to set up mic or Realtex sound card complexly. Instead of using Captive 2 on my vista, I turn to use an audio recorder to record live stream audio, which comes from my plugin USB gadgets or sounds from computer speaker. I have checked that streaming audio recorder can work with vista. This way may help you too.
