2. Re: Shape not aligning properly
Jacob Bugge Jul 30, 2014 5:12 AM (in response to snmbala)snmbala,
How about Align to Pixel Grid?
In cases like this, the first guess is Align to Pixel Grid
You may select everything and then untick Align to Pixel Grid in the Transform pallete, and also untick Align New Objects to Pixel Grid in the flyout options.
You may avoid document types with that as default (RGB for web and the like) or change the default for such documents.
3. Re: Shape not aligning properly
snmbala Jul 30, 2014 5:17 AM (in response to John Mensinger)Have tried this. Not working
4. Re: Shape not aligning properly
snmbala Jul 30, 2014 5:17 AM (in response to John Mensinger)Tried, Not working.
5. Re: Shape not aligning properly
Monika Gause Jul 30, 2014 5:23 AM (in response to snmbala)How is this not working? What's happening instead?
Can you show your artwork with layer panel open?
And show appearance panel with objects selected.
7. Re: Shape not aligning properly
dougofakkad Jul 30, 2014 6:02 AM (in response to snmbala)on your transform palette, check Show options on its dropdown menu, then re-check Jacob's post.
8. Re: Shape not aligning properly
snmbala Jul 30, 2014 6:10 AM (in response to Jacob Bugge)It worked. Its align to pixel gird. thanks buddy.
9. Re: Shape not aligning properly
snmbala Jul 30, 2014 6:11 AM (in response to dougofakkad)You are right it worked
10. Re: Shape not aligning properly
Jacob Bugge Jul 30, 2014 7:14 AM (in response to snmbala)snmbala,
For my part you are welcome.
