18 Replies Latest reply on Aug 7, 2014 3:43 PM by Tim Kurkoski Branched to a new discussion.
    DO NOT install the After Effects 2014.0.1 (13.0.1) update
    Tim Kurkoski Adobe Employee
      UPDATE 2 (August 7, 2014): We have released the After Effects 2014.0.2 (13.0.2) update, which replaces the After Effects CC 2014.0.1 (13.0.1) update.
      After Effects 2014.0.2 (13.0.2) fixes the same bug with the trial period as the previous update. It also corrects the bug with preferences caused by that update. After Effects 2014.0.2 (13.0.2) uses the correct 13.0 preferences folder, and Sync Settings works as expected.
      If you installed the After Effects CC 2014.0.1 (13.0.1) update, and did not reinstall After Effects CC 2014 (13.0) as advised below, you should still install the new update. After you do so note that, due to the preferences bug in the previous update, any changes you made to your preferences or workspaces while using After Effects 2014.0.1 (13.0.1) will be lost; your preferences will return to the state they were in the last time you used After Effects CC 2014 (13.0).
      If you did not not update to After Effects CC 2014.0.1 (13.0.1) or did reinstall as advised, then you will notice no change in your preferences or workspaces after you install the new update.
      UPDATE 1: We have removed the After Effects 2014.0.1 (13.0.1) update from our servers. You should no longer be prompted to update.
      The After Effects team advises you to not install the After Effects 2014.0.1 (13.0.1) update. We have discovered a bug in the update, have removed it from our servers, and are in the process of building a new update. (This update is now available, see Update 2 above.)
      The bug is regarding preferences: the update creates and uses a new preferences folder named 13.0.1. This is not normal procedure for small updates like this one; the updated version is expected to use the existing 13.0 preferences folder, which remains present and unaffected by this problem. When you launch After Effects 2014.0.1 (13.0.1) your preferences will have been reset because it did not copy the files from the 13.0 folder. Also, the Sync Settings functionality will not work.
      We have traced the cause of the problem and will update this forum thread when a new update is available.
      If you have already installed the After Effects 2014.0.1 (13.0.1) update, we recommend that you uninstall After Effects CC 2014 and reinstall, which will restore you to the non-updated version, After Effects CC 2014 (13.0). When you uninstall, do not choose the option to remove preferences, as this will remove the 13.0 preferences folder, not the 13.0.1 preferences folder. You may manually delete the 13.0.1 preferences folder if you wish.
      Our apologies about this problem. We are upset that it occurred; it causes problems for you and reflects poorly on us.
