4 Replies Latest reply: Aug 7, 2014 11:05 PM by mjoshi RSS
    JDBC connection error
    mjoshi Community Member
      I'm trying to create a DSN in ColdFusion Standard v11 server using Sybase jConnect 6.05 JDBC driver connecting to a Sybase SQL AnyWhere 12 Server (running on another server machine). ColdFusion has been installed on a brand new Windows 2012 (Standard) Server and uses IIS 8 for the web server.
      I have done everything mentioned on this page (of course, the driver class and other details have been modified) ColdFusion MX: Configuring the Sybase jConnect 5.5 driver
      When I try to verify the connection in CF Administrator, it throws the following error:
      Connection verification failed for data source: ars_jdbc
      java.sql.SQLException: The method com.sybase.jdbc3.jdbc.SybDatabaseMetaData.getJDBCMajorVersion() has not been completed and should not be called.
      The root cause was that: java.sql.SQLException: The method com.sybase.jdbc3.jdbc.SybDatabaseMetaData.getJDBCMajorVersion() has not been completed and should not be called.
      I know that, all the connection parameters are correct because I have been able to create a DSN on another CF instance (CF 9) to the same database that I am trying to create a DSN for from CF 11. Please guide me in the right direction to fix the problem.
      Thanks.
      Milind
