Show 4 replies
1. Re: how can i draw a straight line with a brush?
Mike Schertzberg Jul 31, 2014 9:07 PM (in response to betdy1345)Straight lines are simple: using the brush click where you want the line to start (you will paint a single spot) then hold down the shift key and click where you want the line to end; Photoshop will draw a straight line between your start and end points.
Additionally, for even more control, you can use the pen tool to create a path, then just stroke the path with the brush.
Mike
2. Re: how can i draw a straight line with a brush?
snmbala Jul 31, 2014 11:07 PM (in response to betdy1345) -
3. Re: how can i draw a straight line with a brush?
betdy1345 Jul 31, 2014 11:16 PM (in response to snmbala)Thank you. I will try the brush click, shift, click method. It sounds quicker than what I found after playing around some more. Drawing a wide line (50 pxls) then applying a blur worked but took a while to update the layer after applying the blur. I guess there is more than one way to fillet the fish huh.
4. Re: how can i draw a straight line with a brush?
snmbala Jul 31, 2014 11:39 PM (in response to betdy1345)true there is always a other way around.
