1. Re: Can this be done using Acrobat Pro XI?
MichaelKazlow Jul 23, 2014 7:38 PM (in response to wallstreet123456@yahoo.co)You do not want to perform OCR. You either want to do Form Recognition (which is overkill for a one off form) or use Text comments/Annotations which work fine for forms most forms but really almost any graphic program will work as well.
2. Re: Can this be done using Acrobat Pro XI?
Bill@VT Aug 1, 2014 10:27 AM (in response to MichaelKazlow)I agree. Just open the scanned form and use one of the text tools or add your own text fields to do your entry. Long time back I use to enter a scanned copy of a form in the header of a document with exact line spacing. I was then able to enter the needed info in the body of the document and print the file. You can do a similar thing with Acrobat or add the form fields yourself. You could try doing a searchable OCR of the scanned form. That will leave the original form as is. Then see if you can do form recognition to create the fields automatically. Never tried it, but might be worth a try.
