4 Replies Latest reply: Aug 16, 2014 1:22 AM by Raphael Fischer | WebDev RSS
    Why does reflow do so much guess work?
    nicofnot Community Member
      I change one element and Reflow tries to keep everything laying out the same. I don't want this to happen! I want to edit one element and not have to go around and clean up the wreck that Reflow created. At the very least, it would be good to ask me what I want to do. Better yet, give me an option to disable it all together.
      For example, if I have an element that is float: right and I decide I don't like it floating right. When I choose float: none, the element is given a left margin to keep it in the very location you don't want it in anymore. This is just a simple example - it gets far worse when making similar revisions to parent elements as each child element could be effected! Also, if an element in the Elements panel is moved around, unexpected styles are applied for no good reason.
      Please tell me why Reflow wants me to do more work. This is just ludicrous.
        • 1. Re: Why does reflow do so much guess work?
          Chris Bank - ReflowDev Adobe Employee
          This is actually a pretty good example of the problem we're trying to solve. If the first case when you are using the PI or moving things around on the canvas we are updating the positioning styles of many elements to try and keep the design visually the same as you had it before.
          In the case of the Elements panels we actually don't change any styles, only the dom order and the results are again not as you expected.
          The current behavior is not perfect, but it's also not as easy as having a switch because people expectations are different in each case. We're definitely looking at it and your feedback is helpful so we'll see what we can come up with.
          Thanks for using Reflow,
          Chris
          • 2. Re: Why does reflow do so much guess work?
            Honestly, I don't understand. Why try so hard to keep the position when a user input says "I want to change the position"? The current behavior makes some sense when the modified element has child elements that need new positioning. But the modified element should only be affected as the user directs. I understand that there may be a case where the user may want the elements position to be recalculated automatically for some reason. So how about a simple dialogue box that asks what the user wants to do with the positioning? I think options such as "automatically maintain element position" and "don't maintain element position" would suffice.
            Thank you for hearing me out. I really want to like Reflow. Hopefully my input can have some impact.
            • 3. Re: Why does reflow do so much guess work?
              Luke ZXCV
              I've also experienced similar issues. If I punch a value in to a field I want to see a result. I certainly don't want any of the other values in other fields to change, possibly unbeknownst to me, as a result. If I drag something around, I'm happy to accept that those values will be changing to allow me to do so, but entering a value manually assumes a sort of precision.
              An rough analogy would be using Illustrator's Transform panel. If I drag an item into a different position and shape, Illustrator automatically resets the values in the Transform field to suit. If I enter a single value into a single field, it changes only that field. The big difference between Illustrator and Reflow is in the relationship between elements. Changes are relatively isolated in Illustrator, there are spacial relationships between elements in Reflow. You guys have really got your work cut out for you figuring that one out! I guess I'd still be expecting that other elements are affected when dragging, but not affected when entering values.
              Thanks for building Reflow,
              Luke
              • 4. Re: Why does reflow do so much guess work?
                First of all i would to say thank you, i know how hard it is to develope a complex software in beloved javascript. I am a little sad, that its closed code, because i am a Js-Developer with great commitment and i love to absorb everything what has to do with Js, Node.js, Node-Webkit and stuff. And also im fascinated, which great stuff is possible with this "tools".
                I think the main problem is that youre trying to do a balancing act between wysiwyg devs an those who are hard code. In my opinion, reflow is a tool, which presumes a comparatively deep understanding of css and its behaviors.
                When i transport the design to code, first i try to get an clean DOM and a base CSS structure. But then, i always went to Firebug and do some finetune stuff. I dont know how many do it this way, but what i can say is that the result is alway the same:
                if i switch between positions or floats or displays, you get always an expectable behavior (ok, sometimes not, sometimes after a cup of coffee ). We could call the behavior "naturally"!
                Thats what i expected in a Software like Reflow. But when you also try to serve the wysiwyg-devs, it will be hard to get a clean behavior!!!
                By the way, what i expected for wysiwyg-devs is muse ?!?
                I would try to imitate the behavior of the Browser-Dev-Tabs, a system what works. i would also try to split the json structure into different pages or blocks to speed up the editor! Because, if you copy one container to another, much more complex container or page, its like to wait for hours (5-10 sec.).
                My actually Project has at the moment roundabout 920kb, but when im finished, it think it would have 2Mb - 4 Mb or more. From my last bigger js-project, i know that at a big json file is not always the best sollution, but i also dont know how your handle the json.
                I am looking very forward for the final product, actually its a little slow in some areas, but i LOVE this clean DOM, (okay, own classes and ids would be nice ^^) and i have a very great respect for your work, because i know how hard it is to create an editor!!!!
                Thanks for building reflow!!
                Raphael
