I'm using Frame 11 to format book chapters. Headings use an autonumber format to indicate successive sections throughout the chapter (i.e., 5.0, 5.1, 5.2, etc.). So headings have section numbers, but there may be multiple paragraphs beneath a heading that are not numbered (e.g., section 5.1 might have 3 paragraphs of text beneath it). I'm using markers to highlight citations within the text paragraphs in order to generate an alphabetical list of citations. But I want the citations in the list to reference section numbers instead of page numbers. Is this possible if every paragraph does not have a corresponding section number? In other words, will a citation in the second paragraph of section 5.1 show § 5.1 (i.e., defaulting to the most recent prior section number if the paragraph in which the citation appears does not have its own section number)? If this is possible, can someone tell me how to set that up? Thanks so much.
There may be more elegant suggestions, but hack this works ...
The point of the point size 2 is to reduce (but, alas, not eliminate, the chances that the paragraph will end up with an extra blank line due to wrapping of the AN). Using the Color Views technique, it will be visible to the author as a tiny greeked artifact.
Cross-References by <$paranum> pick up the current subsection for every such paragraph.
A generated LOP (List of Paragraphs) does as well, although you might have to edit the LOP file's Reference Page APL and change all <$pagenum> to <$paranum>.
Thank you! I'll give that a try.
An alternative to using point size 2 is to set Stretch to [ 0.0% ] in Character Format.
This makes the AN invisible and have zero effect on paragraph formatting (if somewhat harder to see when authoring). So you wouldn't need to use the End of Paragraph positioning with 0 Stretch.
Either approach makes any Paragraph Format using this trick actually be an auto-numbered para for cross-reference and generated list purposes, but not look like one.
It turns out, on testing, that Stretch 0.0% doesn't work. FM silently resets it to 10.0%.
So the autonumbered paragraph with invisible autonumbering solution probably needs to be:
