When I start Captivate I get a message stating that Flash
Player is not installed - and then redirected to the Adobe page
where to download the plugin.
And that is always, even after installing the plugin.
For instance when I click on the link "You can verify the
version you have installed by visiting the About Flash page." I get
the confirmation that Flash Player is actually installed:
"You have version 9,0,47,0 installed".
Please help to avoid it.
Jim
One thing you can try is to simply click Help > Getting
Started Tutorials and run any of the tutorials. These are in .EXE
format and should install any of the components that your computer
thinks is missing. Then retry.
Hi Rick,
Thanks for the information.
But where can I found the link Help > Getting Started
Tutorials ?
If it is in Captivate, I cannot get it as immediatly after
the error msg the software is shut down.
Regards.
Jim
Hi Rick,
That's right !
It tried using the EXE files and even nothing has been
requested for installation, now Captivate is running perfectly.
Many thanks.
Jim
I came across this dialog while searching for the solution to
the issue that carnoy had. My Captivate had been working fine until
it stopped finding the Flash player. Attempting the suggested
opening of one of the executables in the showcase just gives me a
black screen with my mouse pointer showing. What might the next
work around be?
