1 Reply Latest reply: Aug 4, 2014 9:51 AM by Chris Bank - ReflowDev RSS
    Break points not working on copy and paste
    ausmack Community Member
      It looks like copy and paste is not a good option between break points, is that right?
        • 1. Re: Break points not working on copy and paste
          Chris Bank - ReflowDev Adobe Employee
          Copy and paste (as well as duplicate) should work across breakpoints. When you select something it will copy all the styles in all the breakpoints for just that object. For example if you have a page with two breakpoints you have an object that is different in both of them, then when you copy that object and paste into a new page you should get both breakpoints. However if you have a document with two breakpoints and you have an object that is the same in both of them, then when you copy and paste into a new page you won't get one of the breakpoints because that object didn't need it. If this is not what you are seeing then it could be a bug. To tell for sure you can post more steps and details about what you are trying to do.
          Hope that helps and thanks for using Reflow!
          Chris
