quote:
Originally posted by: Peter Grainge
With paths like that you don't need any content in your topics! :-)
If you look at the output, there is a tag <a href>. That should also contain the path and file name. My guess is that you are on track suspecting the length.
Check the length of those that work and those that do not.
Also, I assume the target is in the project.
quote:
Originally posted by: HKabaker
ODoyle,
If I have copied and pasted correctly from your posts, the first path is not the same as the second. It looks like the first has one more level of directories to travel than the second one. If the second one is correct, that means the first would be flagged as a broken link and not carried over into the output.
1.
<a href=
"../../Disbursements_Holds_Refunds_and_Withdrawals/DeVry_Call_Center_Disbursements_Holds_Refunds_and_Withdrawals.htm">Disbursements,
Holds, Refunds and Withdrawals</a>
a href=
(Back up two levels, go into the directory Disbursements_Holds_Refunds_and_Withdrawals,
and open the topic
DeVry_Call_Center_Disbursements_Holds_Refunds_and_Withdrawals.htm)
2.
"../../DeVry_Call_Center_Disbursements_Holds_Refunds_and_Withdrawals.htm">Disbursements, Holds, Refunds and Withdrawals</a>
and open the topic
Or are you saying that the first was correct, and you changed the directory structure in between, so the second also was correct. but the first didn't work because it was too long?
Harvey
