17 Replies Latest reply: Aug 21, 2014 6:11 AM by ronaldjensen RSS
    How to insert a meta tag in the head element in htm topic files?
    ronaldjensen Community Member
      (I am using RoboHelp 9, but have also tried RoboHelp 11 with exactly the same results.)
      Our application requires the WebBrowser control to run in IE9 compatibility mode. This means that when launching help (chm) the help viewer will also use IE9 compatibility mode as it is running in the same process. As Chm files are meant to be viewed in IE7 compatibility mode, this causes various issues with the layout of the help topics.  We have found that to fix this problem each topic needs the following meta tag in the head element:
      <meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7" />
      As our help system consists of several thousand htm/topic files, we can obviously not do this manually. So in order to have this automatically inserted, I need to edit the mother file that generates the topic files. I have tried to find this file, but no luck. Does anybody know how to do this?
