Can RoboHelp 10 be loaded on Windows 8?
Yes it can, but it is not supported on Windows 8. Having said that, you find that you can run RH10 on Windows 8 successfully. The issue mau arise if you find issues. I'd suggest doing some testing before moving to a production environment with that configuration.
Would you have the same answer regarding RoboHelp 10 being loaded on Windows 8.1? Thank you again for answering.
Yes. I am afraid so. Only RoboHelp 11 officially supports Win 8.
Hi there
I'm curious as to the purpose for the question. Have you tried it yet? If so, did it somehow fail? If you haven't tried it, why not?
As Colum said, it will likely work but if you encounter issues you can't really expect Adobe to make any changes as version 11 is the current shipping version.
Cheers... Rick
I have had it running on 8 and 8.1 without trouble but as the others have
indicated, that's my mileage.
Peter... Thom again... can a RoboHelp 10 project be deleted? I've read quite a bit, but can seem to find how to delete a project.
Why post twice?
Just use Window Explorer to trash the folder.
Sorry for the duplicate email entry; still figuring out forum. Thank you for the project delete answer. FYI. You'd think that with all the bells and whistles of Robohelp 10 that they would have a simple delete project option. Also thank you for the Win 8.1 answer. Robohelp loaded just fine.
Sent from my iPad
RoboColumn... Thom again... can a RoboHelp 10 project be deleted? I've read quite a bit, but can seem to find how to delete a project.
