ColdFusion 11 Application Server 3284 | ColdFusion 11 Application Server cannot be found...
Aug 06, 2014 Aug 06, 2014
Trying to roll this server into production but keep having errors popup on Event Viewer:
After dealing with the issue of not being able to restart the CF service and applying the hf1100-3776060.jar hotfix - I continue to receive the following error
The description for Event ID 3 from source ColdFusion 11 Application Server cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
3284
the message resource is present but the message is not found in the string/message table
Any help will be greatly appreciated!
Thank you!
2.1K
Adobe Employee , Aug 07, 2014 Aug 07, 2014
Can you try starting ColdFusion 11 from command prompt.
  1. Stop ColdFusion service
  2. Launch Command prompt as Administrator
  3. Browse to cf_root\cfusion\bin and run the following command coldfusion.exe -start -console
  4. Try to access the CF admin, once the services are started.
In case it gives an error message, please share the same.
Anit Kumar
Guide ,
Any errors or warnings in  CF11\cfusion\logs coldfusion-error and coldfusion-out logs at or before the time of the reported eventvwr.msc message ?
HTH, Carl.
Adobe Employee ,
Anit Kumar
Aug 11, 2014 Aug 11, 2014
Hi Car, there were no errors registered by ColdFusion under the CF11\cfusion\logs coldfusion-error log but the error below continues to show during CF Application stop-start services.
Anit Kumar Panda - followed the steps and was able to restart all services. during that time i received the following error on eventvwr.msc
4140
Thank you, very much, for all your assistance!
Documentation
