If the number of options being returned for filtering is
dynamic, use a formfield name lookup. i.e.
Let's say have a filter form that will submit a series of
filters that must be applied as selection criteria on a database
query. Some of these filters are created on the fly, may have null
values or even support multiple selections. Iterate over the form
elements and perform a type lookup using a UDF based on the field
name, This could be as simple as structkey lookup. In this example
I created a small fieldInfo object which lets me assign multiple
values to the fieldInfo parameters. Though I didn't illustrate it
here, you could even add additional field info such as maxlength.
<cffunction name="getFieldType" returntype="struct">
<cfargument name="fieldName" type="string">
<cfscript>
var fieldInfo = StructNew();
fieldInfo.isList = false;
switch(Arguments.fieldName){
case 'numFilter':
fieldInfo.type = 'cf_sql_integer';
break;
case 'name':
case 'dept':
fieldInfo.type = 'cf_sql_varchar';
break;
case 'multiple':
fieldInfo.isList = true;
break;
default:
fieldInfo.type = '';
break;
</cfscript>
<cfif fieldInfo.type eq "">
<cfthrow message="unknown field name">
</cfif>
<cfreturn fieldInfo>
</cffunction>
<cfquery name="qryFilter" datasource="myDSN">
select mycol1,mycol2,mycol3 from mytable
where
1=1
<cfloop collection="#form#" item="key">
<cfset targetInfo = getFieldType(key)>
<cfif len(form[key]) and targetInfo.isList>
and #key# in(<cfqueryparam cfsqltype="#targetInfo.type#"
list="yes" separator="," value="#form[key]#">)
<cfelseif len(form[key])>
and #key# = <cfqueryparam cfsqltype="#targetInfo.type#"
</cfif>
</cfloop>
</cfquery>
