RH11 - Webhelp
I'm generating mixed font case webhelp and these are the results
This old help file (with remote developers and their calling code files) is needed now - we don't have time to rename and test files. The _1 file is being used and should retain the case.
Why is the _1 upper case not being duplicated?
Thank you
Sigh. Answer is embarrassingly simple. May as well laugh! Project had been renamed to upper case; default topic name had not been changed.
Are you talking about the Start Page file name? Does it have the same name as the Default Topic? Have you changed the Apply Lowercase setting?
Sorry but your question is not clear.
Hi Peter,
Thank you for replying. Yes, the start and default names are the same, which I understand is why <filename_1> is generated. (We can't change the filenames now.)
I did generate lower case one time, but have cleared the "generate lower case" check box as we need initial caps.
When I generate webhelp:
Why isn't it generating both file names with initial caps?
