I am facing an Issue while reading Excel sheet (xls/xlsx) created from Microsoft Office 2013.
Here is the error
#1: An error occurred while reading the Excel: org.apache.poi.EncryptedDocumentException: The supplied spreadsheet seems to be an Encrypted .xlsx file. It must be decrypted before use by XSSF, it cannot be used by HSSF.
#2: An error occurred while reading the Excel: org.apache.poi.hssf.record.RecordFormatException: Unknown encryption info 4.
I tried with CF9 and CF10. Found same error on both versions.
Also, I updated POI jar files with updated POI 3.10 but no luck.
Followed these links :
https://issues.apache.org/bugzilla/show_bug.cgi?id=56564
https://issues.apache.org/bugzilla/show_bug.cgi?id=35897
Any help will be appreciated. Tx
Do you have a sample code to share?
Anit Kumar
<cftry>
<cfspreadsheet action="read"
src="E:\FromD\Test Codes\POIUtility.cfc-master\examples\CFSI_CMRT3-01 (2).xlsx"
name="SpreadsheetObj">
</cfspreadsheet>
<cfdump var="#SpreadsheetInfo(spreadsheetobj)#">
<cfcatch><cfdump var="#cfcatch#"></cfcatch>
</cftry><cfabort>
Here is the excel file: dropbox.com/s/0879kn0da6aoqou/CFSI_CMRT3-01%20(2).xls
I can run the code with ColdFusion 9 and ColdFusion 10. Here's the Output tested with Excel created in 2013.
Can you test the sample code
Dropbox - testSpreadsheet.xlsx
Dropbox - cfspreadsheet_db.cfm
Anit Kumar
Hi Anit,
Did you try with XLSX uploaded over here ?
Also we are facing more issues while reading excel sheets (XLS) -
1.java.lang.NullPointerException at org.apache.poi.hssf.model.LinkTable.getExternalBookAndSheetName
2.Duplicate PageSettingsBlock record (sid=0x89c)
3.The supplied POIFSFileSystem does not contain a BIFF8 'Workbook' entry
Please let me know your findings ?
