2 Replies Latest reply: Aug 8, 2014 9:53 AM by Steve Cordero RSS
    100 inch long pdf?
    zeeebee Community Member
      Hello,
      I am trying to create a long pdf page with Acrobat XI. The only thing I have been able to do so far is convert a Word doc that was 22 inches long to PDF (22 inches is the max for Word).
      In acrobat if I try to insert a page after it, it will add a blank page of the same size.
      also, if in a 8.5x11 pdf then it will insert a blank in the same dimension.
      I am in need of creating a pdf that is the 60 inch to 200 inch range.
      I do not need to print anything so a paper printing mindset is not needed.
      I opened Distiller (whatever that is) and saw an option to make default pages up to 200 inches.
      This would help but how do I use this? Is this something that can give me long pages?
      Any advise is greatly appreciated.
      Thank You,
      -Z
        • 1. Re: 100 inch long pdf?
          I have access to Illustrator (haven't used it much) and will try to create a long pdf with that.
          • 2. Re: 100 inch long pdf?
            Steve Cordero Adobe Employee
            You can do this with a JavaScript documented in the Acrobat SDK
            http://help.adobe.com/livedocs/acrobat_sdk/11/Acrobat11_HTMLHelp/wwhelp/wwhimpl/common/htm l/wwhelp.htm?context=Acrobat11…
            The basic syntax
            app.newDoc(nWidth: , nHeight: );
            This code below is from the Acrobat SDK link above creates a cool menu item that allows for custom size pages.  Note you need to give the size in points.
            trustedNewDoc = app.trustedFunction( function (nWidth, nHeight)
                    app.beginPriv();
                        switch( arguments.length ) {
                            case 2:
                                app.newDoc( nWidth, nHeight );
                                break;
                            case 1:
                                app.newDoc( nWidth );
                                break;
                            default:
                                app.newDoc();
                    app.endPriv();
                app.addSubMenu({ cName: "New", cParent: "File", nPos: 0 })
                app.addMenuItem({ cName: "Letter", cParent: "New", cExec:
                    "trustedNewDoc();"});
                app.addMenuItem({ cName: "A4", cParent: "New", cExec:
                    "trustedNewDoc(420,595)"});
                app.addMenuItem({ cName: "Custom...", cParent: "New", cExec:
                    "var nWidth = app.response({ cQuestion:'Enter Width in Points',\
                        cTitle: 'Custom Page Size'});"
                    +"if (nWidth == null) nWidth = 612;"
                    +"var nHeight = app.response({ cQuestion:'Enter Height in Points',\
                    +"if (nHeight == null) nHeight = 792;"
                    +"trustedNewDoc(nWidth, nHeight) "});
