Thanks for the feedback. Here's what I've come up with.
I created my query and have the cfoutput generate table data
<td> within a
table. This builds the table of images I want nicely. Then I
inserted that
into a spry collapsible panel. Also on each image, I setup an
"on-click"
action to set the variable I need. I've made the panel
collapsed by default.
Now I can click on the panel - it drops down and shows me all
the images;
when I click on the image I get the filename set to a
variable for further
processing.
I didn't know the <cfselect> could only do text. That's
a bummer because it
could be much more flexible and easier to do this with that
option.
"Azadi" <azadi@sabai-dee.com> wrote in message
news:fadmic$abs$3@forums.macromedia.com...
>i believe what you wnat to do is not possible at all...
> <select> and <cfselect> tags are not meant
to display anything but text...
> what you could do as an alternative, is display
thumbnails of your images
> with a checkbox next to each, and have your users check
a checkbox next to
> an image to define their selection?...
> Azadi Saryev
> Sabai-dee.com
http://www.sabai-dee.com
