1. Re: Photomerge parameterization
Noel Carboni Aug 11, 2014 6:34 PM (in response to cyberbaffled)Sure, I've done a lot of really wide panos including some 360 degree ones. Use the "Cylindrical" choice for landscapes, and check the [ ] Blend Images box. You'll likely not notice any distortion unless you're right up next to a straight road or wall.
You say your images are scanned from film... Is there Vignetting in them? If so, you might find that you'll need to process them a bit before stitching them. With all digital conversions Photoshop kind of knows (via lens profiles, etc.) how much correction to make.
By the way, there is a current problem with Photomerge in Photoshop CC 2014.1 (that wasn't there in 2014.0). Are you using the 2014.1 version? If so, do you still have 14.2.1 installed? You might want to use that one instead.
-Noel
2. Re: Photomerge parameterization
cyberbaffled Aug 12, 2014 11:14 AM (in response to cyberbaffled)Noel, thanks for your prompt and informative reply. My scanner allows no vignetting and I'm using Photoshop CS5.5. This will be a somewhat time consuming process, since I'm making the photo(s) available for purchase, however I'll post my experience for you to see.
