2 Replies Latest reply: Aug 12, 2014 7:04 AM by upperpixel RSS
    6 mono tracks to 5.1
    Richard M Knight Community Member
      Often when working in 5.1 surround you are presented with 6 mono L, R, SL,SR, C, LFE tracks to use. In the current and previous versions of Premiere, although there is an easy way to route the 5 main tracks, there is not a easy way to route the LFE. There are a few ways to do this but the technique I prefer is as follows:
      Create a sequence with 7 mono tracks and a 5.1 master track
      Add the mono files as follows:
      Then set up the track mixer like this. Keep all the faders at zero
      Note the joystick panning and the Centre and LFE send controls. Use the Invert audio effect in track 7.
      Then export the sequence as a 'Polywav' 5.1 file. This can then be used in Premiere as a single audio track.
      If you want to change any of the levels of the individual tracks add the 'volume' effect to the new 5.1 wav file.
      Hope this might be of some use.
