1. Re: Elements 12 - not working
saurabh288 Nov 7, 2013 8:57 PM (in response to PoppaJimT)Can you please check if this id is working with adobe site as well?
2. Re: Elements 12 - not working
shikha.. Nov 7, 2013 9:48 PM (in response to PoppaJimT)Hi,
Can you please elaborate more on the issue.What exactly happens after you enter your adobe id?
Do the screen goes away or ask you to enter the details again?
-Shikha
3. Re: Elements 12 - not working
PoppaJimT Nov 8, 2013 5:36 AM (in response to saurabh288)My user ID and password work fine on the adobe site... no problem
4. Re: Elements 12 - not working
PoppaJimT Nov 8, 2013 5:38 AM (in response to shikha..)after I hit enter the sign in window disappears and nothing from adobe appears again
5. Re: Elements 12 - not working
shikha.. Nov 10, 2013 10:26 PM (in response to PoppaJimT)Hi,
Please rename SLCache folder present at location "<root drive:>\Program Files (x86)\Common Files\Adobe\SLCache" and then try to login.
Please update.
Shikha
6. Re: Elements 12 - not working
PoppaJimT Nov 12, 2013 6:43 AM (in response to shikha..)that worked. Elements 12 now functioning. Thanks for the help!
7. Re: Elements 12 - not working
danyelle0318 Apr 19, 2014 12:27 AM (in response to shikha..)Can you please explain how to do this? I am experienceing the same issue, and not sure what you are stating. I found the folder, but unsure what's the next step.
8. Re: Elements 12 - not working
PoppaJimT Apr 19, 2014 5:14 AM (in response to danyelle0318)no problem -
find the folder, then "click" the right mouse button. This should give you a drop down list. Choose "Rename" from the list. Type in a different name for the file and hit "enter"
Sent from Yahoo Mail on Android
9. Re: Elements 12 - not working
suebob22 Aug 12, 2014 1:27 PM (in response to shikha..)I changed the SLcache name and it took me to a bigger loop. Now I get as far as choosing Licensing or Trial...I choose Licensing, enter the correct serial # and it says it's verifying but then I go back to the beginning again...PLEASE HELP ME...I'm so sad that I can't use my newer version!
10. Re: Elements 12 - not working
clogdancer Sep 21, 2014 9:43 AM (in response to shikha..)What shall I rename the file?
I tried giving in just a random name and I geet error 16 when I try to start PSE 12
11. Re: Elements 12 - not working
shikha.. Oct 12, 2014 11:05 PM (in response to suebob22)Hi suebob22,
Please restart your machine and also rename opm.db present at location:C:\Users\<user name>\AppData\Local\Adobe\OOBE
Shikha
12. Re: Elements 12 - not working
shikha.. Oct 12, 2014 11:06 PM (in response to clogdancer)Hi,
Just rename the folder to say - SLCache_old.
Shikha
13. Re: Elements 12 - not working
clogdancer Oct 13, 2014 2:02 AM (in response to shikha..)HI
Thanks for your email. Just to inform you that since I upgraded to windows 8.1 and reinstalled Photoshop 12 it works perfectly
Regards
peter
14. Re: Elements 12 - not working
Photoguy_2014 Nov 1, 2014 3:51 PM (in response to shikha..)Hi shikha, I was given this thread as a reference because I see to be having the same issue. I still haven't been able to fix this. I have done everything that you recommended to suebob22 and still not luck and I don't know if this was ever solved for suebob22. Do you know if she was able to fix it and/or do you have a solution for me?
15. Re: Elements 12 - not working
airbusboy Nov 7, 2014 8:58 AM (in response to Photoguy_2014)Same reply as Photoguy_2014 - I have tried everything suggested in the above, but nothing works.
As soon as I rename the SLCache folder, or opm.db file, PSE12, creates new ones next time I attemp to login and then just hangs at login screen...
16. Re: Elements 12 - not working
Photoguy_2014 Nov 7, 2014 10:56 PM (in response to airbusboy)After 3 days and several attempts with tech support chat I finally got this fixed. I had to talk to a product specialist, but the problem was a proxy setting in internet explorer. Here is a screenshot of what was done. After this was done I was finally able to complete the activation of the software and unlock the full licensed version.
18. Re: Elements 12 - not working
airbusboy Nov 8, 2014 10:33 AM (in response to Photoguy_2014)Thanks for posting your solution.
Unfortunately, it made no difference - although I'm running Windows XP, so your solution may not be appropriate anyway.
Glad to here that you're up and running.
19. Re: Elements 12 - not working
Jenjo8706 Nov 8, 2014 1:36 PM (in response to shikha..)I have this same issue, trying to resolve it. What is the step by step procedure to get to renaming it...? Not really familiar with SL Cache and how to find it...
