Platform is OS X 10.9.4. Download is fine. Installer hangs asking to close applications (Dashboard Client and Safari). Both closed using the activity monitor. Window appears requiring Safari be closed. IT IS CLOSED! This becomes a closed loop.
Since no bright ideas appeared as a result of the log file, I decided to use the Flash Player uninstaller and remove the installed version from my system. I did that and then downloaded the latest flash player version from the Adobe web site.
The new version installed "normally."
Barry
Hello,
Once all apps that use Flash Player are closed, installation should complete. Can you please provide the FlashPlayerInstallManager.log file located at ~/Library/Logs (this is the user's Library not the system Library). The file will most likely be fairly large, as such, please follow the instructions at How to share a document to share the log file.
Thank you.
Maria
That link is completely confusing.
I have attached the log file to this return E-mail.
Barry Hemphill
I would appreciate if you'd explain what exactly is confusing (or unclear) in the instructions I provided in https://forums.adobe.com/thread/1408375
I can make it more clear if you tell me what's wrong with it.
Barry Hemphill
Hi Barry,
Attachments to forums emails will be deleted. The other alternative is to post the contents of the log file here in your post.
Maria
https://files.acrobat.com/preview/...
2011-03-08 07:04:00 -0600 ---------- log start ----------
2011-03-08 07:04:00 -0600 All install checks pass
2011-03-08 07:04:10 -0600 User has 1 process that needs to be closed before the Flash Player can be installed.
2011-03-08 07:04:24 -0600 [install started]
2011-03-08 07:04:26.330 installer[5540:3007] PackageKit: *** Missing bundle identifier: /Library/Receipts/Flip4Mac QuickTime Components.pkg
2011-03-08 07:04:26.334 installer[5540:3007] PackageKit: *** Missing bundle identifier: /Library/Receipts/Flip4Mac Web Plugins.pkg
installer: Package name is PlugIn
installer: Upgrading at base path /
installer: The upgrade was successful.
2011-03-08 07:04:31 -0600 [install completed]
2011-03-08 07:04:31 -0600 [install succeeded]
2011-03-08 07:04:36 -0600 ---------- log end ----------
2011-06-01 06:03:55 -0500 ---------- log start ----------
2011-06-01 06:04:01 -0500 ---------- log end ----------
2011-06-13 05:58:51 -0500 ---------- log start ----------
2011-06-13 05:58:56 -0500 ---------- log end ----------
2011-06-14 14:43:40 -0500 ---------- log start ----------
2011-06-14 14:43:40 -0500 All install checks pass
2011-06-14 14:44:39 -0500 User has 2 processes that need to be closed before the Flash Player can be installed.
2011-06-14 14:44:56 -0500 [install started]
2011-06-14 14:44:56.997 installer[2628:3007] PackageKit: *** Missing bundle identifier: /Library/Receipts/Flip4Mac QuickTime Components.pkg
2011-06-14 14:44:57.000 installer[2628:3007] PackageKit: *** Missing bundle identifier: /Library/Receipts/Flip4Mac Web Plugins.pkg
2011-06-14 14:45:02 -0500 [install completed]
2011-06-14 14:45:02 -0500 [install succeeded]
2011-06-14 14:45:07 -0500 ---------- log end ----------
2011-07-22 04:17:10 +0000 ---------- log start ----------
2011-07-22 04:17:15 +0000 ---------- log end ----------
2011-07-22 04:17:57 +0000 ---------- log start ----------
2011-07-22 04:18:00 +0000 ---------- log end ----------
2011-07-22 04:19:56 +0000 ---------- log start ----------
2011-07-22 04:20:01 +0000 All install checks pass
2011-07-22 04:21:23 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2011-07-22 04:21:33 +0000 [install started]
2011-07-22 04:21:39 +0000 [install completed]
2011-07-22 04:21:39 +0000 [install succeeded]
2011-07-22 04:21:43 +0000 ---------- log end ----------
2011-08-09 20:11:03 +0000 ---------- log start ----------
2011-08-09 20:11:06 +0000 ---------- log end ----------
2011-08-09 20:31:39 +0000 ---------- log start ----------
2011-08-09 20:31:39 +0000 All install checks pass
2011-08-09 20:31:50 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2011-08-09 20:32:00 +0000 [install started]
2011-08-09 20:32:06 +0000 [install completed]
2011-08-09 20:32:06 +0000 [install succeeded]
2011-08-09 20:32:11 +0000 ---------- log end ----------
2011-09-22 15:11:50 +0000 ---------- log start ----------
2011-09-22 15:11:50 +0000 All install checks pass
2011-09-22 15:12:02 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2011-09-22 15:12:02 +0000 [install started]
2011-09-22 15:12:08 +0000 [install completed]
2011-09-22 15:12:08 +0000 [install succeeded]
2011-09-22 15:12:12 +0000 ---------- log end ----------
2011-10-01 12:07:35 +0000 ---------- log start ----------
2011-10-01 12:07:38 +0000 ---------- log end ----------
2011-10-11 10:42:09 +0000 ---------- log start ----------
2011-10-11 10:42:09 +0000 All install checks pass
2011-10-11 10:42:20 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2011-10-11 10:42:31 +0000 [install started]
2011-10-11 10:42:37 +0000 [install completed]
2011-10-11 10:42:37 +0000 [install succeeded]
2011-10-11 10:42:42 +0000 ---------- log end ----------
2011-11-12 14:17:46 +0000 ---------- log start ----------
2011-11-12 14:17:47 +0000 1568
2011-11-12 14:18:17 +0000 14777601
2011-11-12 14:18:18 +0000 verifySignatureWithData : Message Verified!
2011-11-12 14:18:23 +0000 ---------- log end ----------
2011-11-12 14:18:29 +0000 ---------- log start ----------
2011-11-12 14:18:29 +0000 All install checks pass
2011-11-12 14:18:40 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2011-11-12 14:18:50 +0000 [install started]
2011-11-12 14:18:56 +0000 [install completed]
2011-11-12 14:18:56 +0000 [install succeeded]
2011-11-12 14:19:02 +0000 ---------- log end ----------
2012-02-22 11:46:01 +0000 ---------- log start ----------
2012-02-22 11:46:02 +0000 1568
2012-02-22 11:46:29 +0000 14782799
2012-02-22 11:46:30 +0000 verifySignatureWithData : Message Verified!
2012-02-22 11:46:35 +0000 ---------- log end ----------
2012-02-22 11:48:39 +0000 ---------- log start ----------
2012-02-22 11:48:39 +0000 All install checks pass
2012-02-22 11:50:16 +0000 ---------- log end ----------
2012-02-29 14:34:44 +0000 ---------- log start ----------
2012-02-29 14:34:44 +0000 1568
2012-02-29 14:35:09 +0000 14782799
2012-02-29 14:35:09 +0000 verifySignatureWithData : Message Verified!
2012-02-29 14:35:15 +0000 ---------- log end ----------
2012-02-29 14:35:17 +0000 ---------- log start ----------
2012-02-29 14:35:17 +0000 All install checks pass
2012-02-29 14:36:10 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-02-29 14:36:21 +0000 [install started]
2012-02-29 14:36:27 +0000 [install completed]
2012-02-29 14:36:27 +0000 [install succeeded]
2012-02-29 14:36:31 +0000 ---------- log end ----------
2012-03-08 15:26:57 +0000 ---------- log start ----------
2012-03-08 15:27:00 +0000 ---------- log end ----------
2012-03-08 15:28:24 +0000 ---------- log start ----------
2012-03-08 15:28:24 +0000 All install checks pass
2012-03-08 15:28:47 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-03-08 15:28:57 +0000 [install started]
2012-03-08 15:29:03 +0000 [install completed]
2012-03-08 15:29:03 +0000 [install succeeded]
2012-03-08 15:29:08 +0000 ---------- log end ----------
2012-03-08 15:30:41 +0000 ---------- log start ----------
2012-03-08 15:30:41 +0000 All install checks pass
2012-03-08 15:30:50 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-03-08 15:30:50 +0000 [install started]
2012-03-08 15:30:55 +0000 [install completed]
2012-03-08 15:30:55 +0000 [install succeeded]
2012-03-08 15:30:59 +0000 ---------- log end ----------
2012-03-29 15:14:30 +0000 ---------- log start ----------
2012-03-29 15:14:31 +0000 1583
2012-03-29 21:02:03 +0000 11211713
2012-03-29 21:02:03 +0000 verifySignatureWithData : Message Verified!
2012-03-29 21:02:08 +0000 ---------- log end ----------
2012-03-29 21:02:13 +0000 ---------- log start ----------
2012-03-29 21:02:13 +0000 All install checks pass
2012-03-29 21:04:02 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-03-29 21:04:02 +0000 [install started]
2012-03-29 21:04:10 +0000 [install completed]
2012-03-29 21:04:10 +0000 [install succeeded]
2012-03-29 21:04:15 +0000 ---------- log end ----------
2012-04-15 23:00:31 +0000 ---------- log start ----------
2012-04-15 23:00:32 +0000 1583
2012-04-15 23:01:21 +0000 11211575
2012-04-15 23:01:21 +0000 verifySignatureWithData : Message Verified!
2012-04-15 23:01:26 +0000 ---------- log end ----------
2012-04-15 23:01:30 +0000 ---------- log start ----------
2012-04-15 23:01:30 +0000 All install checks pass
2012-04-15 23:01:41 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-04-15 23:01:41 +0000 [install started]
2012-04-15 23:01:48 +0000 [install completed]
2012-04-15 23:01:48 +0000 [install succeeded]
2012-04-15 23:01:52 +0000 ---------- log end ----------
2012-05-08 10:15:13 +0000 ---------- log start ----------
2012-05-08 10:15:15 +0000 1583
2012-05-08 10:15:37 +0000 11210280
2012-05-08 10:15:37 +0000 verifySignatureWithData : Message Verified!
2012-05-08 10:15:43 +0000 ---------- log end ----------
2012-05-08 10:16:42 +0000 ---------- log start ----------
2012-05-08 10:16:42 +0000 All install checks pass
2012-05-08 10:16:52 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-05-08 10:17:05 +0000 [install started]
2012-05-08 10:17:11 +0000 [install completed]
2012-05-08 10:17:11 +0000 [install succeeded]
2012-05-08 10:17:16 +0000 ---------- log end ----------
2012-06-09 10:36:16 +0000 ---------- log start ----------
2012-06-09 10:36:16 +0000 1106
2012-06-09 10:36:38 +0000 11580012
2012-06-09 10:36:38 +0000 verifySignatureWithData : Message Verified!
2012-06-09 10:36:43 +0000 ---------- log end ----------
2012-06-09 10:36:46 +0000 ---------- log start ----------
2012-06-09 10:36:46 +0000 All install checks pass
2012-06-09 10:37:10 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-06-09 10:37:20 +0000 [install started]
sudo: no tty present and no askpass program specified
2012-06-09 10:37:27 +0000 [install completed]
2012-06-09 10:37:27 +0000 [install succeeded]
2012-06-09 10:37:41 +0000 ---------- log end ----------
2012-06-09 10:37:41 +0000 Changing update mode to 1
2012-07-02 09:28:09 +0000 ---------- log start ----------
2012-07-02 09:28:09 +0000 All install checks pass
2012-07-02 09:28:23 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-07-02 09:28:23 +0000 [install started]
2012-07-02 09:28:35 +0000 [install completed]
2012-07-02 09:28:35 +0000 [install succeeded]
2012-07-02 09:29:34 +0000 ---------- log end ----------
2012-07-02 09:29:34 +0000 Changing update mode to 1
2012-07-12 03:48:36 +0000 ---------- log start ----------
2012-07-12 03:48:36 +0000 664
2012-07-12 03:49:06 +0000 11582449
2012-07-12 03:49:06 +0000 verifySignatureWithData : Message Verified!
2012-07-12 03:49:11 +0000 ---------- log end ----------
2012-07-12 03:49:14 +0000 ---------- log start ----------
2012-07-12 03:49:14 +0000 All install checks pass
2012-07-12 03:49:24 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-07-12 03:49:37 +0000 [install started]
2012-07-12 03:49:43 +0000 [install completed]
2012-07-12 03:49:43 +0000 [install succeeded]
2012-07-12 03:49:53 +0000 ---------- log end ----------
2012-07-12 03:49:52 +0000 Changing update mode to 1
2012-07-19 20:21:04 +0000 ---------- log start ----------
2012-07-19 20:21:09 +0000 ---------- log end ----------
2012-07-26 20:38:45 +0000 ---------- log start ----------
2012-07-26 20:38:45 +0000 All install checks pass
2012-07-26 20:38:56 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-07-26 20:39:07 +0000 [install started]
dyld: DYLD_ environment variables being ignored because main executable (/System/Library/PrivateFrameworks/Install.framework/Resources/runner) is setuid or setgid
2012-07-26 20:39:15 +0000 [install completed]
2012-07-26 20:39:15 +0000 [install succeeded]
2012-07-26 20:39:23 +0000 ---------- log end ----------
2012-07-26 20:39:23 +0000 Changing update mode to 1
2012-08-14 20:59:16 +0000 ---------- log start ----------
2012-08-14 20:59:16 +0000 664
2012-08-14 21:01:27 +0000 11583286
2012-08-14 21:01:27 +0000 verifySignatureWithData : Message Verified!
2012-08-14 21:01:32 +0000 ---------- log end ----------
2012-08-14 21:01:36 +0000 ---------- log start ----------
2012-08-14 21:01:36 +0000 All install checks pass
2012-08-14 21:01:45 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-08-14 21:01:45 +0000 [install started]
dyld: DYLD_ environment variables being ignored because main executable (/var/folders/f2/btr7v9yw8xj79f0059blnwmh0000gn/T/FPInstallHelper) is setuid or setgid
2012-08-14 21:01:51 +0000 [install completed]
2012-08-14 21:01:51 +0000 [install succeeded]
2012-08-14 21:02:03 +0000 ---------- log end ----------
2012-08-14 21:02:03 +0000 Changing update mode to 1
2012-08-22 10:38:11 +0000 ---------- log start ----------
2012-08-22 10:38:11 +0000 602
2012-08-22 11:20:04 +0000 11861772
2012-08-22 11:20:04 +0000 verifySignatureWithData : Message Verified!
2012-08-22 11:20:09 +0000 ---------- log end ----------
2012-08-22 11:20:13 +0000 ---------- log start ----------
2012-08-22 11:20:13 +0000 All install checks pass
2012-08-22 11:20:27 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2012-08-22 11:20:27 +0000 [install started]
2012-08-22 11:20:34 +0000 [install completed]
2012-08-22 11:20:34 +0000 [install succeeded]
2012-08-22 11:20:41 +0000 ---------- log end ----------
2012-08-22 11:20:41 +0000 Changing update mode to 1
2012-09-12 19:29:39 +0000 ---------- log start ----------
2012-09-12 19:29:43 +0000 ---------- log end ----------
2012-10-10 09:46:41 +0000 ---------- log start ----------
2012-10-10 09:46:41 +0000 602
2012-10-10 09:47:06 +0000 11866905
2012-10-10 09:47:06 +0000 verifySignatureWithData : Message Verified!
2012-10-10 09:47:11 +0000 ---------- log end ----------
2012-10-10 09:47:18 +0000 ---------- log start ----------
2012-10-10 09:47:18 +0000 All install checks pass
2012-10-10 09:47:29 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-10-10 09:47:41 +0000 [install started]
2012-10-10 09:47:48 +0000 [install completed]
2012-10-10 09:47:48 +0000 [install succeeded]
2012-10-10 09:47:59 +0000 ---------- log end ----------
2012-10-10 09:47:58 +0000 Changing update mode to 1
2012-11-13 21:54:40 +0000 ---------- log start ----------
2012-11-13 21:54:40 +0000 580
2012-11-13 21:55:11 +0000 16875066
2012-11-13 21:55:11 +0000 verifySignatureWithData : Message Verified!
2012-11-13 21:55:16 +0000 ---------- log end ----------
2012-11-13 21:55:23 +0000 ---------- log start ----------
2012-11-13 21:55:23 +0000 All install checks pass
2012-11-13 21:55:33 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-11-13 21:55:43 +0000 [install started]
2012-11-13 21:55:54 +0000 [install completed]
2012-11-13 21:55:54 +0000 [install succeeded]
2012-11-13 21:55:57 +0000 ---------- log end ----------
2012-11-13 21:55:57 +0000 Changing update mode to 0
2013-01-03 10:23:53 +0000 ---------- log start ----------
2013-01-03 10:23:53 +0000 580
2013-01-03 10:24:07 +0000 ---------- log start ----------
2013-01-03 10:24:07 +0000 Changing update mode to 1
2013-01-10 22:40:24 +0000 ---------- log start ----------
2013-01-10 22:40:25 +0000 580
2013-01-10 22:41:17 +0000 16879485
2013-01-10 22:41:17 +0000 verifySignatureWithData : Message Verified!
2013-01-10 22:41:23 +0000 ---------- log end ----------
2013-01-10 22:41:27 +0000 ---------- log start ----------
2013-01-10 22:41:27 +0000 All install checks pass
2013-01-10 22:41:38 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2013-01-10 22:41:38 +0000 [install started]
2013-01-10 22:41:49 +0000 [install completed]
2013-01-10 22:41:49 +0000 [install succeeded]
2013-01-10 22:41:53 +0000 ---------- log end ----------
2013-01-10 22:41:53 +0000 Changing update mode to 0
2013-01-26 03:17:16 +0000 ---------- log start ----------
2013-01-26 03:17:16 +0000 Changing update mode to 1
2013-01-26 03:17:20 +0000 ---------- log start ----------
2013-01-26 03:17:22 +0000 580
2013-02-08 16:37:13 +0000 ---------- log start ----------
2013-02-08 16:37:14 +0000 [install started]
2013-02-08 16:37:25 +0000 [install completed]
2013-02-08 16:37:27 +0000 ---------- log end ----------
2013-02-08 16:37:27 +0000 Changing update mode to 1
2013-02-11 20:36:30 +0000 ---------- log start ----------
2013-02-11 20:36:32 +0000 [install started]
2013-02-11 20:36:45 +0000 [install completed]
2013-02-11 20:36:47 +0000 ---------- log end ----------
2013-02-11 20:36:47 +0000 Changing update mode to 1
2013-02-20 02:33:29 +0000 ---------- log start ----------
2013-02-20 02:33:30 +0000 1214
2013-02-20 02:33:31 +0000 1214
2013-02-20 02:34:47 +0000 16931999
2013-02-20 02:34:48 +0000 verifySignatureWithData : Message Verified!
2013-02-20 02:34:53 +0000 ---------- log end ----------
2013-02-20 02:35:02 +0000 ---------- log start ----------
2013-02-20 02:35:02 +0000 All install checks pass
2013-02-20 02:35:14 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-02-20 02:35:25 +0000 [install started]
2013-02-20 02:35:36 +0000 [install completed]
2013-02-20 02:35:36 +0000 [install succeeded]
2013-02-20 02:35:40 +0000 ---------- log end ----------
2013-02-20 02:35:40 +0000 Changing update mode to 0
2013-02-27 02:36:40 +0000 ---------- log start ----------
2013-02-27 02:36:41 +0000 1214
2013-02-27 02:37:37 +0000 16931542
2013-02-27 02:37:37 +0000 verifySignatureWithData : Message Verified!
2013-02-27 02:37:42 +0000 ---------- log end ----------
2013-02-27 02:37:46 +0000 ---------- log start ----------
2013-02-27 02:37:46 +0000 All install checks pass
2013-02-27 02:37:57 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-02-27 02:38:08 +0000 [install started]
2013-02-27 02:38:21 +0000 [install completed]
2013-02-27 02:38:21 +0000 [install succeeded]
2013-02-27 02:38:25 +0000 ---------- log end ----------
2013-02-27 02:38:25 +0000 Changing update mode to 0
2013-04-10 19:35:56 +0000 ---------- log start ----------
2013-04-10 19:35:56 +0000 1214
2013-04-10 19:36:01 +0000 ---------- log end ----------
2013-04-10 19:37:07 +0000 ---------- log start ----------
2013-04-10 19:37:07 +0000 All install checks pass
2013-04-10 19:37:09 +0000 ---------- log end ----------
2013-04-10 19:37:31 +0000 ---------- log start ----------
2013-04-10 19:37:31 +0000 All install checks pass
2013-04-10 19:37:33 +0000 [install started]
2013-04-10 19:37:46 +0000 [install completed]
2013-04-10 19:37:48 +0000 ---------- log end ----------
2013-05-16 09:37:10 +0000 ---------- log start ----------
2013-05-16 09:37:10 +0000 1214
2013-05-16 09:37:41 +0000 18007571
2013-05-16 09:37:42 +0000 verifySignatureWithData : Message Verified!
2013-05-16 09:37:47 +0000 ---------- log end ----------
2013-05-16 09:37:51 +0000 ---------- log start ----------
2013-05-16 09:37:51 +0000 All install checks pass
2013-05-16 09:38:16 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-05-16 09:38:29 +0000 ---------- log end ----------
2013-05-16 09:40:48 +0000 ---------- log start ----------
2013-05-16 09:40:48 +0000 All install checks pass
2013-05-16 09:40:49 +0000 ---------- log end ----------
2013-05-16 09:41:09 +0000 ---------- log start ----------
2013-05-16 09:41:09 +0000 All install checks pass
2013-05-16 09:41:10 +0000 [install started]
2013-05-16 09:41:21 +0000 [install succeeded]
2013-05-16 09:41:23 +0000 ---------- log end ----------
2013-06-08 04:06:37 +0000 ---------- log start ----------
2013-06-08 04:06:41 +0000 ---------- log end ----------
2013-06-14 12:16:18 +0000 ---------- log start ----------
2013-06-14 12:16:18 +0000 Changing update mode to 1
2013-06-14 12:16:23 +0000 ---------- log start ----------
2013-06-14 12:16:23 +0000 1214
2013-06-26 14:24:10 +0000 ---------- log start ----------
2013-06-26 14:24:10 +0000 1214
2013-07-21 21:58:52 +0000 ---------- log start ----------
2013-07-21 21:58:52 +0000 1213
2013-07-21 21:58:58 +0000 ---------- log end ----------
2013-07-21 22:00:24 +0000 ---------- log start ----------
2013-07-21 22:00:24 +0000 All install checks pass
2013-07-21 22:00:26 +0000 ---------- log end ----------
2013-07-21 22:01:12 +0000 ---------- log start ----------
2013-07-21 22:01:12 +0000 All install checks pass
2013-07-21 22:01:13 +0000 ---------- log end ----------
2013-07-21 22:03:48 +0000 ---------- log start ----------
2013-07-21 22:03:48 +0000 All install checks pass
2013-07-21 22:03:50 +0000 ---------- log end ----------
2013-07-21 22:04:46 +0000 ---------- log start ----------
2013-07-21 22:04:46 +0000 All install checks pass
2013-07-21 22:04:47 +0000 ---------- log end ----------
2013-07-21 22:05:17 +0000 ---------- log start ----------
2013-07-21 22:05:17 +0000 All install checks pass
2013-07-21 22:05:18 +0000 ---------- log end ----------
2013-07-21 22:07:47 +0000 ---------- log start ----------
2013-07-21 22:07:47 +0000 All install checks pass
2013-07-21 22:07:49 +0000 ---------- log end ----------
2013-07-21 22:12:25 +0000 ---------- log start ----------
2013-07-21 22:12:25 +0000 All install checks pass
2013-07-21 22:12:26 +0000 ---------- log end ----------
2013-07-29 15:39:28 +0000 ---------- log start ----------
2013-07-29 15:39:28 +0000 1213
2013-07-29 15:39:29 +0000 1213
2013-07-29 15:39:34 +0000 ---------- log end ----------
2013-07-29 15:40:47 +0000 ---------- log start ----------
2013-07-29 15:40:47 +0000 All install checks pass
2013-07-29 15:40:48 +0000 ---------- log end ----------
2013-07-29 15:41:11 +0000 ---------- log start ----------
2013-07-29 15:41:11 +0000 All install checks pass
2013-07-29 15:41:11 +0000 [install started]
2013-07-29 15:41:22 +0000 [install succeeded]
2013-07-29 15:41:24 +0000 ---------- log end ----------
2013-07-29 15:41:24 +0000 Changing update mode to 1
2013-08-13 13:21:40 +0000 ---------- log start ----------
2013-08-13 13:21:40 +0000 1213
2013-09-11 11:02:39 +0000 ---------- log start ----------
2013-09-11 11:02:39 +0000 1214
2013-09-11 11:02:40 +0000 1214
2013-09-11 11:03:04 +0000 18133029
2013-09-11 11:03:04 +0000 verifySignatureWithData : Message Verified!
2013-09-11 11:03:09 +0000 ---------- log end ----------
2013-09-11 11:03:15 +0000 ---------- log start ----------
2013-09-11 11:03:15 +0000 All install checks pass
2013-09-11 11:03:28 +0000 User has 2 processes that need to be closed before the Flash Player can be installed.
2013-09-11 11:03:42 +0000 [install started]
2013-09-11 11:03:48 +0000 [install completed]
2013-09-11 11:03:48 +0000 [install succeeded]
2013-09-11 11:03:55 +0000 ---------- log end ----------
2013-09-11 11:03:55 +0000 Changing update mode to 1
2013-09-19 13:02:45 +0000 ---------- log start ----------
2013-09-19 13:02:52 +0000 ---------- log end ----------
2013-10-09 13:15:14 +0000 ---------- log start ----------
2013-10-09 13:15:15 +0000 1389
2013-10-09 13:15:39 +0000 18408578
2013-10-09 13:15:39 +0000 verifySignatureWithData : Message Verified!
2013-10-09 13:15:44 +0000 ---------- log end ----------
2013-10-09 13:15:49 +0000 ---------- log start ----------
2013-10-09 13:15:49 +0000 All install checks pass
2013-10-09 13:16:00 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-10-09 13:16:10 +0000 [install started]
installer: Package name is Adobe Flash Player
2013-10-09 13:16:21 +0000 [install completed]
2013-10-09 13:16:21 +0000 [install succeeded]
2013-10-09 13:16:28 +0000 ---------- log end ----------
2013-10-09 13:16:28 +0000 Changing update mode to 1
2013-11-13 14:32:22 +0000 ---------- log start ----------
2013-11-13 14:32:22 +0000 1389
2013-11-13 14:32:23 +0000 1389
2013-11-13 14:32:29 +0000 ---------- log end ----------
2013-11-13 14:34:19 +0000 ---------- log start ----------
2013-11-13 14:34:19 +0000 All install checks pass
2013-11-13 14:34:20 +0000 [install started]
2013-11-13 14:34:32 +0000 [install succeeded]
2013-11-13 14:34:32 +0000 ---------- log end ----------
2013-11-13 14:34:32 +0000 Changing update mode to 1
2013-12-17 12:29:04 +0000 ---------- log start ----------
2013-12-17 12:29:04 +0000 1389
2013-12-17 12:29:29 +0000 18417494
2013-12-17 12:29:29 +0000 verifySignatureWithData : Message Verified!
2013-12-17 12:29:34 +0000 ---------- log end ----------
2013-12-17 12:29:38 +0000 ---------- log start ----------
2013-12-17 12:29:38 +0000 All install checks pass
2013-12-17 12:29:52 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-12-17 12:30:04 +0000 [install started]
2013-12-17 12:30:15 +0000 [install completed]
2013-12-17 12:30:15 +0000 [install succeeded]
2013-12-17 12:30:27 +0000 ---------- log end ----------
2013-12-17 12:30:27 +0000 Changing update mode to 1
2014-01-12 15:14:05 +0000 ---------- log start ----------
2014-01-12 15:14:05 +0000 1389
2014-01-13 15:00:51 +0000 ---------- log start ----------
2014-01-13 15:00:51 +0000 1389
2014-01-19 13:01:29 +0000 ---------- log start ----------
2014-01-19 13:01:29 +0000 1386
2014-01-19 13:01:33 +0000 ---------- log start ----------
2014-01-19 13:01:34 +0000 1386
2014-01-19 13:01:41 +0000 ---------- log end ----------
2014-01-19 05:03:44 -0800 IM: ---------- log start ----------
2014-01-19 05:03:44 -0800 IM: All install checks pass
2014-01-19 05:03:46 -0800 IM: User does not have any processes that need to be closed.
2014-01-19 05:03:46 -0800 IM: [install started]
2014-01-19 05:03:49 -0800 FIN: [finalizer started]
2014-01-19 05:03:49 -0800 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-01-19 05:03:49 -0800 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-01-19 05:03:52 -0800 FIN: [finalizer succeeded]
2014-01-19 05:03:57 -0800 IM: [install succeeded]
2014-01-19 05:03:57 -0800 IM: ---------- log end ----------
2014-02-05 07:02:49 -0800 IM: ---------- log start ----------
2014-02-05 07:02:49 -0800 IM: 1386
2014-02-05 07:02:51 -0800 IM: ---------- log start ----------
2014-02-05 07:02:51 -0800 IM: 1386
2014-02-05 07:03:17 -0800 IM: 18450331
2014-02-05 07:03:21 -0800 IM: ---------- log end ----------
2014-02-05 07:03:21 -0800 IM: ---------- log start ----------
2014-02-05 07:03:21 -0800 IM: All install checks pass
2014-02-05 07:03:33 -0800
2014-02-05 07:03:44 -0800 IM: [install started]
2014-02-05 07:03:46 -0800 FIN: [finalizer started]
2014-02-05 07:03:46 -0800 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-02-05 07:03:46 -0800 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-02-05 07:03:48 -0800 FIN: [finalizer succeeded]
2014-02-05 07:03:55 -0800 IM: [install completed]
2014-02-05 07:03:55 -0800 IM: [install succeeded]
2014-02-05 07:03:58 -0800 IM: ---------- log end ----------
2014-02-21 12:23:10 -0800 IM: ---------- log start ----------
2014-02-21 12:23:10 -0800 IM: All install checks pass
2014-02-21 12:23:10 -0800 IM: [install started]
2014-02-21 12:23:13 -0800 FIN: [finalizer started]
2014-02-21 12:23:13 -0800 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-02-21 12:23:13 -0800 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-02-21 12:23:15 -0800
2014-02-21 12:23:21 -0800 IM: [install succeeded]
2014-02-21 12:23:21 -0800 IM: ---------- log end ----------
2014-03-02 06:36:55 -0800 IM: ---------- log start ----------
2014-03-02 06:36:55 -0800 IM: 1386
2014-03-17 04:52:01 -0700 IM: ---------- log start ----------
2014-03-17 04:52:01 -0700 IM: 1386
2014-03-17 04:52:26 -0700 IM: 18419293
2014-03-17 04:52:31 -0700 IM: ---------- log end ----------
2014-03-17 04:52:36 -0700 IM: ---------- log start ----------
2014-03-17 04:52:36 -0700 IM: All install checks pass
2014-03-17 04:52:52 -0700
2014-03-17 04:52:59 -0700 IM: [install started]
2014-03-17 04:53:01 -0700 FIN: [finalizer started]
2014-03-17 04:53:01 -0700 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-03-17 04:53:01 -0700 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-03-17 04:53:03 -0700 FIN: [finalizer succeeded]
2014-03-17 04:53:10 -0700 IM: [install completed]
2014-03-17 04:53:10 -0700 IM: [install succeeded]
2014-03-17 04:53:13 -0700 IM: ---------- log end ----------
2014-03-20 07:17:45 -0700 IM: ---------- log start ----------
2014-03-20 07:17:46 -0700 IM: 1386
2014-04-08 14:46:03 -0700 IM: ---------- log start ----------
2014-04-08 14:46:03 -0700 IM: 1387
2014-04-08 14:46:04 -0700 IM: 1387
2014-04-08 14:49:34 -0700 IM: ---------- log end ----------
2014-04-08 14:51:16 -0700 IM: ---------- log start ----------
2014-04-08 14:51:16 -0700 IM: All install checks pass
2014-04-08 14:51:17 -0700 IM: User does not have any processes that need to be closed.
2014-04-08 14:51:17 -0700 IM: [install started]
2014-04-08 14:51:21 -0700 FIN: [finalizer started]
2014-04-08 14:51:21 -0700 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-04-08 14:51:21 -0700 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-04-08 14:51:23 -0700 FIN: [finalizer succeeded]
2014-04-08 14:51:29 -0700 IM: [install succeeded]
2014-04-08 14:51:29 -0700 IM: ---------- log end ----------
2014-04-22 15:31:42 -0700 IM: ---------- log start ----------
2014-04-22 15:31:43 -0700 IM: 1387
2014-04-22 15:32:04 -0700 IM: 15721099
2014-04-22 15:32:09 -0700 IM: ---------- log end ----------
2014-04-22 15:32:13 -0700 IM: ---------- log start ----------
2014-04-22 15:32:13 -0700 IM: All install checks pass
2014-04-22 15:32:36 -0700
2014-04-22 15:32:46 -0700 IM: ---------- log end ----------
2014-04-22 15:35:51 -0700 IM: ---------- log start ----------
2014-04-22 15:35:52 -0700 IM: 1387
2014-04-22 15:35:55 -0700 IM: ---------- log start ----------
2014-04-22 15:35:55 -0700 IM: 1387
2014-04-22 15:36:15 -0700 IM: 15721099
2014-04-22 15:36:19 -0700 IM: ---------- log end ----------
2014-04-22 15:36:19 -0700 IM: ---------- log start ----------
2014-04-22 15:36:19 -0700 IM: All install checks pass
2014-04-22 15:36:28 -0700
2014-04-22 15:36:39 -0700 IM: [install started]
2014-04-22 15:36:41 -0700 FIN: [finalizer started]
2014-04-22 15:36:41 -0700 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-04-22 15:36:41 -0700 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-04-22 15:36:43 -0700 FIN: [finalizer succeeded]
2014-04-22 15:36:50 -0700 IM: [install completed]
2014-04-22 15:36:50 -0700 IM: [install succeeded]
2014-04-22 15:37:13 -0700 IM: ---------- log end ----------
2014-04-29 15:39:28 -0700 IM: ---------- log start ----------
2014-04-29 15:39:29 -0700 IM: 1387
2014-04-29 15:39:51 -0700 IM: 15715106
2014-04-29 15:39:56 -0700 IM: ---------- log end ----------
2014-04-29 15:39:59 -0700 IM: ---------- log start ----------
2014-04-29 15:39:59 -0700 IM: All install checks pass
2014-04-29 15:40:10 -0700
2014-04-29 15:40:14 -0700 IM: ---------- log end ----------
2014-04-29 15:41:15 -0700 IM: ---------- log start ----------
2014-04-29 15:41:15 -0700 IM: 1387
2014-04-29 15:41:18 -0700 IM: ---------- log start ----------
2014-04-29 15:41:18 -0700 IM: 1387
2014-04-29 15:41:42 -0700 IM: 15715106
2014-04-29 15:41:46 -0700 IM: ---------- log end ----------
2014-04-29 15:41:46 -0700 IM: ---------- log start ----------
2014-04-29 15:41:46 -0700 IM: All install checks pass
2014-04-29 15:41:56 -0700
2014-04-29 15:42:09 -0700 IM: [install started]
2014-04-29 15:42:12 -0700 FIN: [finalizer started]
2014-04-29 15:42:12 -0700 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-04-29 15:42:12 -0700 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-04-29 15:42:13 -0700 FIN: [finalizer succeeded]
2014-04-29 15:42:20 -0700 IM: [install completed]
2014-04-29 15:42:20 -0700 IM: [install succeeded]
2014-04-29 15:42:27 -0700 IM: ---------- log end ----------
2014-05-16 05:35:32 -0700 IM: ---------- log start ----------
2014-05-16 05:35:32 -0700 IM: 1387
2014-05-16 05:35:38 -0700 IM: ---------- log start ----------
2014-05-16 05:35:38 -0700 IM: 1387
2014-05-16 05:36:03 -0700 IM: 15723551
2014-05-16 05:36:07 -0700 IM: ---------- log end ----------
2014-05-16 05:36:07 -0700 IM: ---------- log start ----------
2014-05-16 05:36:07 -0700 IM: All install checks pass
2014-05-16 05:36:18 -0700
2014-05-16 05:36:30 -0700 IM: [install started]
2014-05-16 05:36:32 -0700 FIN: [finalizer started]
2014-05-16 05:36:32 -0700 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-05-16 05:36:32 -0700 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-05-16 05:36:34 -0700 FIN: [finalizer succeeded]
2014-05-16 05:36:41 -0700 IM: [install completed]
2014-05-16 05:36:41 -0700 IM: [install succeeded]
2014-05-16 05:36:48 -0700 IM: ---------- log end ----------
2014-05-21 13:46:06 -0700 IM: ---------- log start ----------
2014-05-21 13:46:07 -0700 IM: 1387
2014-05-23 07:07:14 -0700 IM: ---------- log start ----------
2014-05-23 07:07:21 -0700 IM: ---------- log end ----------
2014-06-10 18:20:31 -0700 IM: ---------- log start ----------
2014-06-10 18:20:31 -0700 IM: 1387
2014-06-10 18:20:36 -0700 IM: ---------- log end ----------
2014-06-10 18:21:55 -0700 IM: ---------- log start ----------
2014-06-10 18:21:55 -0700 IM: All install checks pass
2014-06-10 18:21:57 -0700 IM: User does not have any processes that need to be closed.
2014-06-10 18:21:57 -0700 IM: [install started]
2014-06-10 18:22:01 -0700 FIN: [finalizer started]
2014-06-10 18:22:01 -0700 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-06-10 18:22:01 -0700 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-06-10 18:22:02 -0700 FIN: [finalizer succeeded]
2014-06-10 18:22:08 -0700 IM: [install succeeded]
2014-06-10 18:22:08 -0700 IM: ---------- log end ----------
2014-06-15 06:57:20 -0700 IM: ---------- log start ----------
2014-06-15 06:57:20 -0700 IM: 1387
2014-06-15 06:57:28 -0700 IM: ---------- log start ----------
2014-06-15 06:57:28 -0700 IM: 1387
2014-07-09 06:41:41 -0700 IM: ---------- log start ----------
2014-07-09 06:41:41 -0700 IM: 1387
2014-07-09 06:41:42 -0700 IM: 1387
2014-07-09 06:42:02 -0700 IM: 16326619
2014-07-09 06:42:07 -0700 IM: ---------- log end ----------
2014-07-09 06:42:11 -0700 IM: ---------- log start ----------
2014-07-09 06:42:11 -0700 IM: All install checks pass
2014-07-09 06:42:24 -0700
2014-07-09 06:42:37 -0700 IM: [install started]
2014-07-09 06:42:39 -0700 FIN: [finalizer started]
2014-07-09 06:42:39 -0700 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-07-09 06:42:39 -0700 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-07-09 06:42:41 -0700 FIN: [finalizer succeeded]
2014-07-09 06:42:48 -0700 IM: [install completed]
2014-07-09 06:42:48 -0700 IM: [install succeeded]
2014-07-09 06:42:54 -0700 IM: ---------- log end ----------
2014-08-12 16:28:34 -0700 IM: ---------- log start ----------
2014-08-12 16:28:34 -0700 IM: 1407
2014-08-12 16:28:38 -0700 IM: ---------- log start ----------
2014-08-12 16:28:38 -0700 IM: 1407
2014-08-12 16:28:45 -0700 IM: ---------- log end ----------
2014-08-12 16:30:12 -0700 IM: ---------- log start ----------
2014-08-12 16:30:12 -0700 IM: All install checks pass
2014-08-12 16:30:14 -0700
2014-08-12 16:30:14 -0700 IM: ---------- log end ----------
2014-08-12 16:31:03 -0700 IM: ---------- log start ----------
2014-08-12 16:31:03 -0700 IM: All install checks pass
2014-08-12 16:31:04 -0700
2014-08-12 16:31:04 -0700 IM: ---------- log end ----------
2014-08-12 16:31:38 -0700 IM: ---------- log start ----------
2014-08-12 16:31:38 -0700 IM: All install checks pass
2014-08-12 16:31:39 -0700
2014-08-12 16:31:39 -0700 IM: ---------- log end ----------
2014-08-12 16:31:47 -0700 IM: ---------- log start ----------
2014-08-12 16:31:47 -0700 IM: All install checks pass
2014-08-12 16:31:48 -0700
2014-08-12 16:31:48 -0700 IM: ---------- log end ----------
2014-08-12 16:31:50 -0700 IM: ---------- log start ----------
2014-08-12 16:31:50 -0700 IM: All install checks pass
2014-08-12 16:31:51 -0700
2014-08-12 16:31:51 -0700 IM: ---------- log end ----------
2014-08-12 16:32:17 -0700 IM: ---------- log start ----------
2014-08-12 16:32:17 -0700 IM: All install checks pass
2014-08-12 16:32:18 -0700
2014-08-12 16:32:18 -0700 IM: ---------- log end ----------
2014-08-12 16:33:13 -0700 IM: ---------- log start ----------
2014-08-12 16:33:13 -0700 IM: All install checks pass
2014-08-12 16:33:14 -0700
2014-08-12 16:33:14 -0700 IM: ---------- log end ----------
2014-08-12 16:33:24 -0700 IM: ---------- log start ----------
2014-08-12 16:33:24 -0700 IM: All install checks pass
2014-08-12 16:33:26 -0700
2014-08-12 16:33:26 -0700 IM: ---------- log end ----------
2014-08-12 16:33:59 -0700 IM: ---------- log start ----------
2014-08-12 16:33:59 -0700 IM: All install checks pass
2014-08-12 16:34:01 -0700
2014-08-12 16:34:01 -0700 IM: ---------- log end ----------
2014-08-12 16:34:02 -0700 IM: ---------- log start ----------
2014-08-12 16:34:02 -0700 IM: All install checks pass
2014-08-12 16:34:03 -0700
2014-08-12 16:34:03 -0700 IM: ---------- log end ----------
2014-08-12 16:34:20 -0700 IM: ---------- log start ----------
2014-08-12 16:34:20 -0700 IM: All install checks pass
2014-08-12 16:34:21 -0700
2014-08-12 16:34:21 -0700 IM: ---------- log end ----------
2014-08-12 16:35:50 -0700 IM: ---------- log start ----------
2014-08-12 16:35:50 -0700 IM: All install checks pass
2014-08-12 16:35:51 -0700
2014-08-12 16:35:51 -0700 IM: ---------- log end ----------
2014-08-12 16:35:57 -0700 IM: ---------- log start ----------
2014-08-12 16:35:57 -0700 IM: All install checks pass
2014-08-12 16:35:59 -0700
2014-08-12 16:35:59 -0700 IM: ---------- log end ----------
2014-08-12 16:36:00 -0700 IM: ---------- log start ----------
2014-08-12 16:36:00 -0700 IM: All install checks pass
2014-08-12 16:36:01 -0700
2014-08-12 16:36:01 -0700 IM: ---------- log end ----------
2014-08-12 16:36:02 -0700 IM: ---------- log start ----------
2014-08-12 16:36:02 -0700 IM: All install checks pass
2014-08-12 16:36:03 -0700
2014-08-12 16:36:03 -0700 IM: ---------- log end ----------
2014-08-12 16:36:04 -0700 IM: ---------- log start ----------
2014-08-12 16:36:04 -0700 IM: All install checks pass
2014-08-12 16:36:05 -0700
2014-08-12 16:36:05 -0700 IM: ---------- log end ----------
2014-08-12 16:36:06 -0700 IM: ---------- log start ----------
2014-08-12 16:36:06 -0700 IM: All install checks pass
2014-08-12 16:36:07 -0700
2014-08-12 16:36:07 -0700 IM: ---------- log end ----------
2014-08-12 16:36:08 -0700 IM: ---------- log start ----------
2014-08-12 16:36:08 -0700 IM: All install checks pass
2014-08-12 16:36:09 -0700
2014-08-12 16:36:09 -0700 IM: ---------- log end ----------
2014-08-12 16:36:10 -0700 IM: ---------- log start ----------
2014-08-12 16:36:10 -0700 IM: All install checks pass
2014-08-12 16:36:11 -0700
2014-08-12 16:36:11 -0700 IM: ---------- log end ----------
2014-08-12 16:36:12 -0700 IM: ---------- log start ----------
2014-08-12 16:36:12 -0700 IM: All install checks pass
2014-08-12 16:36:13 -0700
2014-08-12 16:36:13 -0700 IM: ---------- log end ----------
2014-08-12 16:37:00 -0700 IM: ---------- log start ----------
2014-08-12 16:37:00 -0700 IM: 1407
2014-08-12 16:37:03 -0700 IM: ---------- log start ----------
2014-08-12 16:37:03 -0700 IM: 1407
2014-08-12 16:37:11 -0700 IM: ---------- log end ----------
2014-08-12 16:38:51 -0700 IM: ---------- log start ----------
2014-08-12 16:38:51 -0700 IM: All install checks pass
2014-08-12 16:38:53 -0700
2014-08-12 16:38:53 -0700 IM: ---------- log end ----------
2014-08-12 16:39:02 -0700 IM: ---------- log start ----------
2014-08-12 16:39:02 -0700 IM: All install checks pass
2014-08-12 16:39:03 -0700
2014-08-12 16:39:03 -0700 IM: ---------- log end ----------
2014-08-12 16:39:06 -0700 IM: ---------- log start ----------
2014-08-12 16:39:06 -0700 IM: All install checks pass
2014-08-12 16:39:07 -0700
2014-08-12 16:39:07 -0700 IM: ---------- log end ----------
2014-08-12 16:39:07 -0700 IM: ---------- log start ----------
2014-08-12 16:39:07 -0700 IM: All install checks pass
2014-08-12 16:39:08 -0700
2014-08-12 16:39:09 -0700
2014-08-12 16:39:09 -0700 IM: ---------- log end ----------
2014-08-12 16:39:09 -0700 IM: ---------- log start ----------
2014-08-12 16:39:09 -0700 IM: All install checks pass
2014-08-12 16:39:10 -0700
2014-08-12 16:39:10 -0700 IM: ---------- log end ----------
2014-08-12 16:39:11 -0700 IM: ---------- log start ----------
2014-08-12 16:39:11 -0700 IM: All install checks pass
2014-08-12 16:39:12 -0700
2014-08-12 16:39:12 -0700 IM: ---------- log end ----------
2014-08-12 16:39:13 -0700 IM: ---------- log start ----------
2014-08-12 16:39:13 -0700 IM: All install checks pass
2014-08-12 16:39:14 -0700
2014-08-12 16:39:14 -0700 IM: ---------- log end ----------
2014-08-12 16:39:15 -0700 IM: ---------- log start ----------
2014-08-12 16:39:15 -0700 IM: All install checks pass
2014-08-12 16:39:16 -0700
2014-08-12 16:39:16 -0700 IM: ---------- log end ----------
2014-08-13 06:18:07 -0700 IM: ---------- log start ----------
2014-08-13 06:18:08 -0700 IM: 1407
2014-08-13 06:18:11 -0700 IM: ---------- log start ----------
2014-08-13 06:18:11 -0700 IM: 1407
2014-08-13 06:18:19 -0700 IM: ---------- log end ----------
2014-08-13 06:20:33 -0700 IM: ---------- log start ----------
2014-08-13 06:20:33 -0700 IM: All install checks pass
2014-08-13 06:20:34 -0700
2014-08-13 06:20:34 -0700 IM: ---------- log end ----------
2014-08-13 06:21:28 -0700 IM: ---------- log start ----------
2014-08-13 06:21:28 -0700 IM: All install checks pass
2014-08-13 06:21:29 -0700
2014-08-13 06:21:29 -0700 IM: ---------- log end ----------
2014-08-13 06:21:51 -0700 IM: ---------- log start ----------
2014-08-13 06:21:51 -0700 IM: All install checks pass
2014-08-13 06:21:52 -0700
2014-08-13 06:21:53 -0700
2014-08-13 06:21:53 -0700 IM: ---------- log end ----------
2014-08-13 06:21:54 -0700 IM: ---------- log start ----------
2014-08-13 06:21:54 -0700 IM: All install checks pass
2014-08-13 06:21:55 -0700
2014-08-13 06:21:55 -0700 IM: ---------- log end ----------
2014-08-13 06:21:56 -0700 IM: ---------- log start ----------
2014-08-13 06:21:56 -0700 IM: All install checks pass
2014-08-13 06:21:57 -0700
2014-08-13 06:21:57 -0700 IM: ---------- log end ----------
2014-08-13 06:21:58 -0700 IM: ---------- log start ----------
2014-08-13 06:21:58 -0700 IM: All install checks pass
2014-08-13 06:22:00 -0700
2014-08-13 06:22:00 -0700 IM: ---------- log end ----------
2014-08-13 06:24:03 -0700 IM: ---------- log start ----------
2014-08-13 06:24:03 -0700 IM: All install checks pass
2014-08-13 06:24:04 -0700
2014-08-13 06:24:04 -0700 IM: ---------- log end ----------
2014-08-13 06:24:19 -0700 IM: ---------- log start ----------
2014-08-13 06:24:19 -0700 IM: All install checks pass
2014-08-13 06:24:20 -0700
2014-08-13 06:24:20 -0700 IM: ---------- log end ----------
2014-08-13 06:24:22 -0700 IM: ---------- log start ----------
2014-08-13 06:24:22 -0700 IM: All install checks pass
2014-08-13 06:24:23 -0700
2014-08-13 06:24:23 -0700 IM: ---------- log end ----------
Pardon the link that leads to a page that is not useful....hopefully the cut/paste of the log file will be helpful to someone who might have a solution to my problem.
Barry
Barry
