1. Re: After Effects will RAM Preview not in real time
Rick Gerard Aug 13, 2014 2:53 PM (in response to T00n3)60 fps is a very high frame rate not usually supported. If your footage is shot at 60i then it is probably 29.97 fps when converted to progressive video. If the footage is actually 60 fps then you will be better off, and by better off I mean more folks and streaming services will be able to view your video at the proper speed.
So my recommendation is to first determine your audience and then set up your comp appropriately. In all my years in the business I have only delivered one high frame rate project and that was 48 fps.
The other thing I would recommend is to optimize your system for AE. That does not necessarily mean throw all your available ram and processors at the app. There are some good recommendations here: Optimizing After Effects Performance
2. Re: After Effects will RAM Preview not in real time
Szalam Aug 13, 2014 3:06 PM (in response to T00n3)T00n3 wrote:
It's not a footage/project issue because the entire project (a blend of tiff, png, prores422) can be played 120 frames/sec without any problem on after CS5
Wait, how did you get an AE comp with a frame rate higher than 100?.
3. Re: After Effects will RAM Preview not in real time
Todd_Kopriva Aug 14, 2014 8:50 AM (in response to Szalam)I just deleted three duplicates of this post on other threads. Do not post duplicate posts.
4. Re: After Effects will RAM Preview not in real time
Rick Gerard Aug 14, 2014 8:51 AM (in response to Szalam)actually... higher than 99???
5. Re: After Effects will RAM Preview not in real time
T00n3 Aug 14, 2014 9:06 AM (in response to T00n3)We are making a music video with "dive" (a kind of oculus technology) that need a high frame rate.
It will be downloaded on iphones to be viewed in 360° with a special thing strapped on you head.
We know our audience, we make videos since year 2000 (you can check our website machinemolle dot com)
I have read the adobe recommendations (we're a small professional studio, we make high definition 2d and 3d content, we are aware about this)
The problem ALSO occurs when previewing in 30fps !
In CS5 the preview is ok in 60fps.
In CS6/CC the preview is not ok at 30fps.
In both case we use the same computer, and a small portion of ram is used for the preview.
What kind of test would you advise ?
6. Re: After Effects will RAM Preview not in real time
T00n3 Aug 19, 2014 2:21 AM (in response to Rick Gerard)Sorry, My teammate said 120 but it is not possible on AE. He was getting upset on this problem and said it should even run 120 but hasn't tried.
I apologies for that bad information.
7. Re: After Effects will RAM Preview not in real time
T00n3 Aug 19, 2014 2:22 AM (in response to Szalam)Sorry, My teammate said 120 but it is not possible on AE. He was getting upset on this problem and said it should even run 120 but hasn't tried.
8. Re: After Effects will RAM Preview not in real time
T00n3 Aug 19, 2014 6:18 AM (in response to T00n3) -
9. Re: After Effects will RAM Preview not in real time
T00n3 Aug 19, 2014 6:24 AM (in response to T00n3)
