I have a FLex 2.0.1 front end and am calling Java/Spring
Remote Objects.
In my app I can create a new Request. I call the
save(requestVO) method and pass it a requestVO. In the requestVO,
there is a boolean property called newObject that specifies that
this is a new request. This works fine.
However in my app I can also perform a search and am returned
back an array of RequestVOs. I select one RequestVO, update a
property and ensure the newObject boolean is set to false (since
this is not a new request) and I pass this requestVO to the
save(requestVO) method again. When I do this I get the following
UnmarshalException:
java.rmi.UnmarshalException : error unmarshalling arguments;
nested exception is:
java.lang.ClassNotFoundException:
flex.messaging.io.ArrayCollection: This error could indicate that a
component was deployed on a cluster member but not other members of
that cluster. Make sure that any component deployed on a server
that is part of a cluster is also deployed on all other members of
that cluster
The java developers unit tests work fine so it seems there is
a problem when flex is trying to rebuild the VO to send it back?
Does anyone have any ideas on this???
Thanks...
