I am trying to use a drop down list to control how my field calculate. I have events packages that have multiple tiers. For example, Package One has (2) Tiers. Tier 1 costs $16 & Tier 2 costs $20. So based on the number of guests i want to be able to select the tier and it multiply and give me the total cost for the package. Ex: 2 Guests for Tier 1 = $32. Here is the code i have so far, it is placed under the change handler of the drop down list:
var costPerGuest = 16;
var tier = event.newText;
if (tier == "Tier 1"){
costPerGuest = 16;}
else if (tier == "Tier 2"){
costPerGuest = 20;}
Total.rawValue = String(Guests.rawValue * costPerGuest)
//Total.rawValue = DropDownList1.rawValue;
What happens is when I run this it will not change unless the number of guests will change. So for the example above, if i switch it to Tier 2 after selecting Tier 1, it will not change my Total from $32 to $40.
Any help would be greatly appreciated.
Total Likes
If you use the calculate event of the Total field you'll have more luck. As soon as you change the dropdown or the guests field it will update
Total Likes
I think ,you can use the event of EXIT event of dropdown list.
var costPerGuest = 0;
if (this.rawValue == "Tier1")
costPerGuest = 16;
else if (this.rawValue == "Tier2")
costPerGuest = 20;
else
total.rawValue = Guests.rawValue * costPerGuest;
Hope this helps,
S,Candy.
Total Likes
Thank you Steve! This worked. I appreciate your help!
Total Likes
