1 Reply Latest reply: Aug 14, 2014 12:03 AM by boboxjordan RSS
    Export multiple entries in CSV format - Adobe Captivate Results Analyzer
    Babellebumskin Community Member
      I'm currently developing and testing a quiz in Captivate 8, which I have set up with the assistance of my IT colleagues to report to an internal server.
      All appears to be working correctly with regard to capturing the data. I can access and read the data using Adobe Captivate Quiz Results Analyzer 1.5.
      I note that I can see the individual responses and I can drill down to see the details of the interactions - interaction type, correct answer, student answer etc.
      My issue is that it seems that you can't batch export this detailed information for multiple participants when I use the 'Export to CSV' function. It appears to only allow you to export the data for each individual that you have drilled down into. Given that I have several hundred participants that isn't going to work.
      Can someone tell me if this is a limitation of Adobe Captivate Results Analyzer or is there a way to do this using this tool?
