Robohelp HTML 10 (10.0.0.287) - generating WebHelp output for a website - How do I import a CSS style sheet?
I've inherited a Help project that does not have a CSS file in the Project Files folder. Is there a way to import a CSS file into an existing Help project?
I’m pretty sure that it’s impossible for a RH 10 project to be created without CSS being present – if only with one called “default.css” – every topic can have its own CSS associated with it, so I’d be tempted to just copy what you want out of “your” CSS & paste it into the default one in use.
Hi there
Right-click and choose Properties (or Topic Properties) for any topic. Then click the Appearance tab. On this tab is an icon you may click to browse your operating system and choose the desired CSS.
Cheers... Rick
Thanks, Jeff and Rick, for your quick replies. I was premature in posting my question. I should have looked around in the other folders under Project Files or I could have looked in the HTML code of one of the topic files and seen that the CSS file was in a different folder. I didn't create this project so I don't know how the CSS file wound up where it did. For now, I will leave it where it is. Also, an extra thank you to Rick ... I didn't know I could import a CSS file through the Topic Properties Appearance tab.
