ChooseFile not working to open a directory ?
Advocate ,
Aug 15, 2014 Aug 15, 2014
Hi all,
I am creating an installer for my scripts and need to get an istall directory from the customer. It seems that ChooseFile ( ) with the ChooseOpenDir parameter is exactly what I need. But this does not work: there is no dialog and the return value is always null. Does anyone else experience this? Is this a bug in FM or just something wrong in my FM installation? I am running FM 12.0.0.308 on Windows 7.
Ciao
Jang
Scripting
590
Hi Jang,
Post your code and I will try it here. Or, you could ExtendScript's built-in Folder methods:
var folder = Folder(app.OpenDir).selectDlg ("Select a folder:");
or
var folder = Folder.selectDialog ("Select a folder:");
The major difference is that selectDlg lets you start with a default folder selected.
Rick
Engaged ,
Jang,
I always use openDlg function of Folder class. This works well for my use cases.
I think I discovered the same issue former times and decided to use Folder class.
Hope this helps
Markus
BTW: I wrote and extend script installer some time ago. practice innovation | SWATFMINSTALLSCRIPTS
Mentor ,
Hi Jang,
It works for me, something like this:
var path = ChooseFile("Browse for folder", "", "", Constants.FV_ChooseOpenDir);
alert(path);
One thing though... there is a bug in the interface where the prompt will fail and just return null if the start path is bogus:
var path = ChooseFile("Browse for folder", "C:\\Some\\Bogus\\Path", "", Constants.FV_ChooseOpenDir);
Make sure that the path is a valid folder, if you are specifying one. It might even give you problems if the path points to a file, even if valid.
Russ
