Here's the problem: Using Captivate, I have created a full
motion recording of an application. When the output is viewed it
appears as a series of slides; each slide a single screen shot with
mouse movement and text captions.) I want to take one slide at a
time (with its mouse movement and text captions) and insert it as
an one-slide animation into an already existing slide. Every time I
try to insert just one slide out of a recording, I get the entire
multi-slide animation.
(I am doing an "insert animation", instead of an "import
recording", because my project uses a background slide with
multiple panes and the animation has to fit inside one of these
panes. If I import the slides, they can't be reduced to fit in the
pane.)
Does anyone have any suggestions? Thanks in advance for your
help!
