1. Re: Why does it take so long when adding a new topic in RH10 with PushOK SVN
Captiv8r Aug 15, 2014 7:33 AM (in response to tojo45)Hi there
The behavior you are describing would seem to indicate the project is actually stored on a network drive. Now I know that source control simply HAS to be in a central location, but generally when you configure it for use, you have the main repository on a server somewhere, but you also nominate a "Working Folder" which is usually on your local file system. (C: or D:) So when you check out a topic to work on it, the Working folder maintains the local copy and there should be no lag. When you check it back in, the local copy is then copied back to the main repository.
Perhaps check to ensure you have configured a local location for the Working Folder?
Cheers... Rick
2. Re: Why does it take so long when adding a new topic in RH10 with PushOK SVN
tojo45 Aug 15, 2014 7:59 AM (in response to Captiv8r)Rick,
Thanks for the quick response. We do have a working copy on our own machines, with the repository holding the source control version. I agree it sounds as though that is what's happening. Being new users to this system perhaps there's a setting we are missing. I'll do some further testing and report back the results.
Joe
