1. Re: Premiere Pro Cs4 Cuts Of The Sides Of My Video
Ann Bens Aug 3, 2014 12:24 PM (in response to {DGJ})What is the height and width of the original video and what preset did you use?
2. Re: Premiere Pro Cs4 Cuts Of The Sides Of My Video
{DGJ} Aug 5, 2014 7:21 AM (in response to Ann Bens)The original video frame height and width is 1360x768. The preset i use is hd capture format and HDV 720p 30fps.
3. Re: Premiere Pro Cs4 Cuts Of The Sides Of My Video
Ann Bens Aug 5, 2014 1:45 PM (in response to {DGJ})There is your answer.
720P is 1280x720. You need to scale it down. You will never get it to fit on all sides.
4. Re: Premiere Pro Cs4 Cuts Of The Sides Of My Video
{DGJ} Aug 6, 2014 6:46 AM (in response to {DGJ})Oh ok so it will never fit on all sides.I always stretch the picture out. It so if i do it in 1080p will it fit on all sides
5. Re: Premiere Pro Cs4 Cuts Of The Sides Of My Video
Ann Bens Aug 6, 2014 10:45 AM (in response to {DGJ})You can do that if you want your picture to look distorted.
6. Re: Premiere Pro Cs4 Cuts Of The Sides Of My Video
{DGJ} Aug 6, 2014 1:39 PM (in response to Ann Bens)So i should just leave it the way it is when i first open everything up
7. Re: Premiere Pro Cs4 Cuts Of The Sides Of My Video
Ann Bens Aug 7, 2014 6:29 AM (in response to {DGJ})I would make a 720p timeline and scale it down (without stretching) to fit all sides.
This means you will loose some image on the sides.
edit: just tested fits perfectly.
8. Re: Premiere Pro Cs4 Cuts Of The Sides Of My Video
{DGJ} Aug 7, 2014 6:35 AM (in response to Ann Bens)Thank you so much! if there is anyway i can help you rank up or something tell me
9. Re: Premiere Pro Cs4 Cuts Of The Sides Of My Video
{DGJ} Aug 16, 2014 7:45 AM (in response to Ann Bens)That Didn't Work i scale it down to fit all sides and it's still doing the same thing.
10. Re: Premiere Pro Cs4 Cuts Of The Sides Of My Video
Ann Bens Aug 16, 2014 8:08 AM (in response to {DGJ})You probably need to uncheck the option Scale to Fit Framesize in the Preferences.
