It there a maximum amount of Ram that can be allocated the the virtual file system? When I specify more than 1 GB size, the system returns a negative number for the remaining free space, and any attempt to store a file resuts in storage limit exceeded errors.
I've been unable to locate much detail about the VFS configuration via web searches. Any details are appreciated.
Ronnie
This is why i hate this forum people get no response to questions!!
Ronnie, did you find a solution to your question?
Well, you will also get that when you have $25 in your pocket, but spend $32. It is easy to find out how much memory you have. Search for Coldfusion java.lang.Runtime on the web. You will find something like
<cfscript>
rt = CreateObject("java","java.lang.Runtime").getRuntime();
memory = StructNew();
memory.freeAllocated = rt.freeMemory() / 1024^2;
memory.total = rt.totalMemory() / 1024^2;
memory.max = rt.maxMemory() / 1024^2;
memory.used = memory.total - memory.freeAllocated;
memory.freeTotal = memory.max - memory.total + memory.freeAllocated;
memory.heapMemory = memory.used;
</cfscript>
<cfdump label="Memory in MB" var="#memory#">
