Show 2 replies
1. Re: Is there a limit to volume/quantity of pics?
resdesign Aug 17, 2014 5:14 AM (in response to AdrienneMASmith)Right now there is not a way inside Edge to delete extra files. You will need to delete your files from the images folder. When you return to Edge it will warn you that files have been deleted and adk if you want to update your composition. Click OK.
if you deleted a file by mistake, you can replace it in the folder. If you give it a different name, you will have to relink the image by selecting it and relinking it in the left panel.
if you have a symbol that you are not using and has a deleted file, you will need to delete it as well to avoid an error message.
that's it.
2. Re: Is there a limit to volume/quantity of pics?
AdrienneMASmith Aug 17, 2014 5:13 PM (in response to resdesign)Thanks, I guess backup files are necessary.
How about program capacity? What kind of limits are there?
