Would greatly appreciate some help with this issue, I haven't been able to find anything online about it.
I'm using RoboHelp 11.02 (just upgraded from 11.01) on a 64 bit Windows 7 PC. When I try to Insert DHTML Effects, such as when a file has loaded, fade it in, I get the error "line 4233 char 2 Unable to get property ‘alpha’ of undefined or null reference code 0 File .../ehlpdhtm.js"
Here's that part of the code.
4231 CAgencyAlpha.prototype.PrepareEffect = function()
4232 {// to set the visual filter function
4233 // the visual filter ONLY work when set by "Width and Height" or
4234 // absolute position for DIV, SPAN and normal tag ( such as p )
4235 // but, "absolute" cause the following elements overlap, so:
4236 CCSSP.PrepareFilter( this.ele );
4237 CCSSP.ShowObject(this.ele, !this.bIsIn );
4238 }
and when I try to View a Browser Sequence (in another project) that I've added (to a Microsoft Help file), I see the message “line 354, char 4 error “HHComponentActivator” is undefined code 0"
But line 354 is //End to support previous generic parameters.
I searched for HHComponentActivator and found a few lines later,
357 function BsHHActivateComponents()
358 {
359 if( HH_ActiveX && (HH_ChmFilename != "") && ((self == top) || (self == top.frames[0])))
360 {
361 var objBody = getElementsByTag(document,"BODY")[0];
362 if( typeof(objBody) == "object" )
363 {
364 insertAdjacentHTML(objBody, "beforeEnd", '<OBJECT ID="HHComponentActivator" CLASSID="CLSID:399CB6C4-7312-11D2-B4D9-00105A0422DF" width=0 height=0></OBJECT>');
365 if (HHComponentActivator.object)
366 HHComponentActivator.Activate(HH_ChmFilename, HH_WindowName, HH_GlossaryFont, HH_Glossary, HH_Avenue);
367 }
368 }
369}
Any help is appreciated, I'd really like to get this resolved!
