Pie Charts in InDesign
Participant ,
Aug 19, 2014 Aug 19, 2014
Can you create pie charts like the ones in the attached image? If so, how?
How to , Scripting
52.6K
Community Expert , Aug 19, 2014 Aug 19, 2014
Do it in another software like Illustrator and place it in InDesign.
Participant ,
Ok. Thanks.
Valorous Hero ,
They are relatively easy to make in ID. It is pretty much the same as using Illustrator.
Make two circles, center them. I color them differently just so I can see them.
Select both, use the Object menu, Pathfinder, Subtract. You will then have the outer ring.
Create a rectangle the width that you desire to create the segment separation.
Center it on the ring, like shown in the above screen shot.
Holding Alt/Option down, rotate the thin rectangle, let go and that will create a copy.
Once you get enough lines, create a compound path with them.
Select the outer ring and the rectangles that were made into a compound path.
Subtract again.
Release the compound path and each segment can be colored.
Mike
Aug 20, 2014 Aug 20, 2014
There's the script solution http://www.indiscripts.com/post/2010/06/claquos2-pie-chart-builder-for-indesign
Or you can use a font called Chartwell
You can draw them manually (but who wants to do that?)
You could make them in Excel and print it to a PDF - then place that. (Or open the PDF in Illustrator to tidy up and apply your colours)
You could make them in Illustrator (although I find Excel more pleasant to work with in this particular area)
Agree with Eugene - there are some scripts around that will generate pie graphs... Marc Autret's "Claquos" script is one, there are others... great for one-off graphs, but if there are many, then chartwell font is the solution. That isn't free but it is a good solution if there is dozens - if not hundreds - of graphs to do.
If the answer wasn't in my post, perhaps it might be on my blog at colecandoo!
Guide ,
Feb 04, 2020 Feb 04, 2020
Hi everyone,
Claquos 2020 (Pie Chart Builder for InDesign) is now available with many new features.
Claquos 3.0 for InDesignClaquos 3.0 for InDesign
The TRY version manages up to 5 slices but lets you enjoy all functionalities 🙂 Should be OK for demo layouts and simple projects.
Main page: http://indiscripts.com/category/projects/Claquos
Best,
Marc
