That is a great message because it tells you that
a) Your developer is calling HH_HELP_CONTEXT (The right call
for map numbers)
b) The map number is 50001, and
c) Your help file, "MainHelp.chm," does not contain a topic
linked to map number 50001.
What you should do from here is to assign a topic to that map
number. The Edit MapIDs option in your project should allow you to
do this. Then, after you compile, the application should fire that
topic.
Why aren't you getting the same info from RH BugHunter? I
don't know. I have only used the newer versions of RH briefly as
trial versions.
John
