I have some applications developed on older CF versions (9&10) and in anticipation of a hosting system migrating to CF11 and started doing some testing with a CF development platform on Windows 8 with Apache 2.4. I have found that in CF11 pages using cflayout and cflayoutarea does not work correctly when collapsed with javascript:ColdFusion.Layout.collapseArea. Firebug does flag an error in the CF javascript. Wondering if anyone else has seen a problem like this and if there is a circumvention I could use to get this working. A very simple example (complements of the Chapter 2 cflayout example demonstrated in Dan Short's video on Ajax & Coldfusion) fails as well on CF11 but works in CF9 & CF10. main.cfm
content.cfm
I tried your code and received an "h.substr is not a function" from extjs. I don't know why. I do know that a lot of the extjs based tags broke in Coldfusion 11. They upgraded to extjs 4.1 and did not do their testing. I would log this as a bug in the Adobe bug base.
Thanks for taking the time to check it out for me. I was expecting similar results. I have run my tests with the un-minified javascript which gives a little clearer, but equally useless detail: "collapseDir,substr is not a function" The message shows the error is on line 49878 of the debug version of ext-all.js.
The rumblings I have seen online are that the cflayout feature is not robust enough to be depended upon. Moreover, I cannot wait holding my breath in hopes that it might be fixed. I will have to look for other ways to accomplish what I need to do without using cflayout. It had the potential to be a very useful feature.
use <CFAJAXIMPORT tag and make sure you have the CFIDE folder as a virtual directory in your IIS local or server machine. if the "cfajaximport" tag alone didn't work, try using it in little more details to the path of CFIDE folder and specify cflayout within the cfajaximport tag as follows:
<CFAJAXIMPORT
CSSSRC = "CFIDE/scripts/ajax/"
SCRIPTSRC = "/CFIDE/scripts"
TAGS = "cfdiv,cfform,cfgrid,cfinput-autosuggest,cfinput-datefield,cflayout-border,cflayout-tab,cfmenu,cftextarea,cftooltip,cftree,cfwindow">
Normally, you shouldn't need all these specifications in the cfajaximport but in case you may try it in more detail as shown above.
Thanks for an idea. I did try this, with a number of variations, with the same error results.
