4 Replies Latest reply: Aug 22, 2014 12:32 PM by pixxxel schubser RSS
    Adjust tracking (character spacing) of selected text
    kevinljohnston Community Member
      I am looking for a script that will allow me to apply a specific tracking value to selected text in InDesign. I'm not even an amateur in scripting.
      I found the following script in the referenced article: Script:  Adjust tracking (character spacing) of text
      <javascriptresource>
      <name>Character Tracking...</name>
      <enableinfo>true</enableinfo>
      <menu>automate</menu>
      <about>Adjust the kerning.</about>
      <category>Typography</category>
      </javascriptresource>
      if (app.documents.length > 0) {
          var targettext = app.activeDocument.activeLayer.textItem;
          targettext.tracking = parseInt(prompt("Select the tracking value", 0));
      This looks like it's approximately what I would like to do. Two problems, I think it is just designed for Photoshop(?), and secondly, I want to use it for only selected text, not the entire page. Also,I would like to apply the script to a keyboard shortcut (I assume that's possible).
      Can anyone assist in this? Sorry to ask, but I've got a large two-column document with large amounts of tracking to do and looking for shortcuts for clicking or typing in the tracking drop-down box.
      Many thanks!
        • 1. Re: Adjust tracking (character spacing) of selected text
          pixxxel schubser Community Member
          For InDesign?
          Why you need a script? This is always built in and works with selected text!
          InDesign Help | Default keyboard shortcuts
          Have fun
          • 2. Re: Adjust tracking (character spacing) of selected text
            [Jongware] Community Member
            Your sample does indeed not look like it's using InDesign's version of the DOM (Document Object Model). Fortunately, if you already selected some text, it's dead easy:
            app.selection[0].tracking = 100;
            where you can set the "100" to any value that is valid for tracking. For added nicenessness, if you really have to set this value a lot, assign a hotkey to this script: open the Keyboard Shortcut Editor, scroll down to Scripts, and select yours, then set some key combo.
            See Adobe InDesign CS5.5 (7.5) Object Model JS: Text for tracking, and a lot more properties you can immediately assign.
            • 3. Re: Adjust tracking (character spacing) of selected text
              Thanks to both Plxxxel and Jongware!
              Both of your answers were helpful - I have combined use of both.
              Plxxxel - I was aware there was a shortcut (Alt+Left Arrow, Alt+Right Arrow) for incrementing tracking by the amount set in Edit, Preferences, Units & Increments, Kerning & Tracking.  What I didn't realize was that Ctrl+Alt+Right Arrow, Ctrl+Alt+Left Arrow increments/decrements that setting by 5 times. So, for my usage, I have set Tracking at 1.  Then I use the Crtl+Alt arrow combinations for rougher (5 incr.) spacing and Alt arrow combinations for fine (1 incr.) tuning. That actually is the practical solution for me.
              Jongware - Thanks for your scripting solution! Your answer was correct according to what I asked in my original question.
              I found it can be more useful if I adapt it to increment additional tracking amounts:
                   <name>Character Tracking. Increase</name>
                   app.selection[0].tracking = app.selection[0].tracking + 10;
                   [Similar script for Character Tracking.Decrease.]
              So assigning these scripts to keyboard shortcuts like Alt+1, Q, I have:
                   Alt +  arrow = increment by 1
                   Ctrl+Alt + arrow = increment by 5
                   Alt 1/Q = increment by 10
              Actually, my needs are sufficiently met by just using the built-in Alt and Ctrl+Alt arrow combinations, but thought I would document the simple script alternative in case anyone could make use of it.
              I think I have graduated to becoming an amateur.
              Thanks again to both of you for your help!
              • 4. Re: Adjust tracking (character spacing) of selected text
                Hi kevinljohnston,
                glad to help you.
                And I'm with you. Using both answers is a good practice.
                Have fun
                @all admins, why isn't there no possibility to mark any answers as helpful. IMHO it is always a hard decision to say which answer is really correct. That was much better before the Jive update!
