Show 2 replies
1. Re: Photoshop CS4:Fatal error
R_Kelly Aug 21, 2014 7:02 PM (in response to SmElton)Reinstall photoshop cs4.
Don't forget to reapply any updates like 11.0.2 for photoshop cs4 after reinstalling.
You get the needed updates from here:
2. Re: Photoshop CS4:Fatal error
mnights101345544 Nov 22, 2014 8:08 PM (in response to SmElton)Ok, after reading tons of threads trying to get a simple answer here are the main points:
- You do not need to reinstall anything.
- Locate a backup , Time Machine or anyplace where you may have a backup of your Adobe Suite Install.
- In both Locations( Hard Drive and Backup) Navigate to: Macintosh HD > Library > Application Support > Adobe > Adobe Version Cue CS4 > Client
- Once there you will see your problem Adobe is looking for folder named 4.0.0 and you have 4.0.1
- Fix: Find the backup and copy over folder named "4.0.0" , Problem solved!
- Open up Adobe Photoshop CS4 and problem should be fixed.
Observations:
Upon inspecting folder 4.0.1, I did notice there were exactly 5 (.framework) files just like in folder 4.0.0 with the exception of 4.0.0 having a "Dictionaries" folder. where 4.0.1 has this folder missing. I am not sure how important this particular folder may be, However if by any chance you do not have a backup It might be possible to just change the 4.0.1 folders name to 4.0.0. and this just might work, In theory that is . Good Luck!
