Error "Status code:403" al usar cffileupload
Aug 21, 2014 Aug 21, 2014
I using a cffileupload to upload a file into server, but the component give me an error "Status code:403". Somebody have any idea?
408
Enthusiast ,
Aug 22, 2014 Aug 22, 2014
Are you running cffileupload over https? If yes, then it is a bug in ColdFusion 10.
Also, share the code?
thanks for your comments.
I not using HTTPS yet because I working in development enviropment, and I have coldfusion 9 and Apache in the server.
I have two files, the first have next code:
<cfoutput>
<script type='text/javascript'>
  var cierra=function cerrarVentana(){
  window.close();
  var error_carga=function error(e){
  alert("Estado:"+e.STATUS+"\n  Mensaje: "+e.MESSAGE+"\n Archivo:"+e.FILENAME);
</script>
<cffileupload
    url="uf_xxx.cfm?ids=#url.ids#&fe=#url.fe#&#urlEncodedFormat(session.urltoken)#"
    progressbar="true"
    name="upload"
    addButtonLabel = "Agregar Archivo"
    clearButtonlabel = "Limpiar"
    hideUploadButton = "false"
    width=500
    height=200
    title = "Carga de archivos"
    extensionfilter="*.xls"
    BGCOLOR="##FFFFFF"
    MAXFILESELECT=1
    UPLOADBUTTONLABEL="Cargar archivo"
    onUploadComplete = cierra
    onError=error_carga
    maxuploadsize="20"
    stoponerror=true
the second file is uf_xxx.cfm and have the next code:
<cftry>
  <cffile action="uploadAll" destination="#expandpath('../../archivo')#" nameconflict="overwrite">
    <cfset stock = createObject("component","#Application.webroot#/component")>
  <cfset res=stock.recibe_stock("#expandpath('../../archivo/#cffile.serverFileName#.xls')#",url.ids, url.fe)>
    <cfcatch type="any">
    <cfset str.STATUS = 500>
  <cfset str.MESSAGE = "Error durante la carga del archivo">
        <cfquery datasource="db" >
            insert into logerror values(sysdate,'error', 'error')
        </cfquery>
    </cfcatch>
</cftry>
When I try it, the file not up and the second file not execute and in the cffileupload component appers the message "Status code: 403".
I think that is a configuration issue but I not find the solution yet.
Enthusiast ,
Try this
  <cffile action="uploadAll" destination="#expandpath('../../archivo')#" nameconflict="overwrite" accept="application/vnd.ms-excel">
thanks again.
I tried your suggestion but i have the same error.
Documentation
