Show 2 replies
1. Re: Is it possible to reuse the map file that was produced to map FrameMaker styles to RoboHelp when creating a PDF in RoboHelp?
Peter Grainge Aug 25, 2014 8:08 AM (in response to ENTRGWH)I suspect that even if you could find the mapping information (pass as to where) it would simply tell you that Style A in Fm was mapped to Style B in Rh but not give you any information about how Style A was defined in Fm.
I think your only options are to create a CSS as you suggest or, as I would, create redefine the Word Style Mapping Template to suit. By going to Word first, you can edit the output for better page breaks and other tweaking you might want.
2. Re: Is it possible to reuse the map file that was produced to map FrameMaker styles to RoboHelp when creating a PDF in RoboHelp?
ENTRGWH Aug 26, 2014 7:05 AM (in response to Peter Grainge)Thanks Peter.
I hadn't considered going to Word first. It does sound like the best option, though.
