5 Replies Latest reply: Aug 26, 2014 2:35 AM by Yardena RSS
    exporting
    Yardena Community Member
      hey,
      I want to know how do i keep my edited video in the current format while exporting it to the computer?
      meaning: the format of the shots as they were filmed in hd camere is mov and they weight alot over than 100MB for a shot and all together the entire video clip should weight nearly 2 GB  and I want to keep it in that format and quality, so how do i do that?
      thanks,
      Yardena
        • 1. Re: exporting
          I want to export the video clip in it's original format as it was filmed.
          • 2. Re: exporting
            Ann Bens CommunityMVP
            2 gig is not much.
            If you want to export to the same format you need to use Quicktime instead of H.264.
            If you want the same quality you can use the animation codec but that will make huge files.
            Is it just for playing back on a computer, then mp4 will be fine. Choose a HD preset from the list.
            • 3. Re: exporting
              yeah, in the animation codec the files are huge.
              so i choose: quick time
              then which codec shall i choose?
              i found no mp4 format in my program
              and anyways each time i'm choosing the preset or the codec it changes automatically when the preset changes to custom and the codec changes to h.264
              can you please demonstrate the exact process with a photo shoot?
              thanks,
              Yardena
              • 4. Re: exporting
                mjshade Community Member
                I can't say for sure what your source codec is, but judging from the filenames on your timeline, it looks like you shot with a Canon DSLR. The codec for Canon MOVs is H.264, as far as I know.
                So, my recommendation would be to export with the following settings:
                Format: Quicktime
                Codec: H.264
                Quality: 100%
                Resolution: 1920x1080
                Frame rate and field order will depend on what you shot in. Look in your project window for this information.
                Aspect: Square Pixels
                See below for reference.
                If you find that your filesize is too high, check "Limit data rate" and experiment with different values. Higher values = better quality and larger file sizes. Smaller values = worse quality and smaller file sizes.
                • 5. Re: exporting
                  wow, you're all awesome.
                  I'll try that one.
                  thank you all, appreciate it.
